Old 01-23-2005, 04:02 PM   #1
toddbrowne
Member#: 79843
Yellow
Question Crank Pulley
I've tried both directions attempting to loosen the bolt on the crank pulley on an EJ25. Before I jump on a mile long extension with all my Bohemian girth I like to verify the thread direction, anyone sure?
toddbrowne is offline   Reply With Quote
Old 01-23-2005, 04:10 PM   #2
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Old 01-23-2005, 05:46 PM   #3
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Lefty-loosie
Old 01-23-2005, 05:52 PM   #4
toddbrowne
Member#: 79843
Yellow
Thanks. Wanted to make sure, already busted one socket on it. Me thinks tis a wee bit over-torqued Scotty.
Old 01-23-2005, 09:21 PM   #5
Uncle Scotty
Member#: 16200
OK buy Nates beans
.....well if you aren't using a GOOD 1/2" drive, 6pt socket.....you are pissing in the wind.....5th gear and have someone stand on the brake pedal and use a 3ft pipe on your longest breaker bar.....DO NOT HIT/DENT THE HOOD.
You may need to 'tap' the pulley off with a plastic hammer or mallet....
DO NOT LOOSE THE WOODRUFF KEY!!!!!!!!!
Old 01-24-2005, 12:55 AM   #6
Pakin
Member#: 17315
MY95 Impreza 207C
MY05 Forester 257X
Assuming you don't have any cheap tools. (DO NOT ATTEMPT with tools of questionable quality)
Use the engine, it's there for you.
What I do is have a 1/2" breaker bar with that 22mm six-point, place it snug and "pre-cranked" onto the pulley bolt.
Then lay the handle (should be long enough) end on the driver-side fender/frame near the battery area, making sure nothing is in the way (eg: PS lines, AC lines). It is important to have the handle on the frame area snug (by having it be "pre-cranked from the engine) and not loose or hovering above the surface.
Double check to make sure the socket is fully seated in the bolt.
With everything in place, crank the engine from the starter lightly for about a quarter of a second
You'll hear the bolt break loose and voila, repeat if it's not loose.
IBProperTechnicianFlaming
-paK +5
Pakin is offline   Reply With Quote
Old 01-24-2005, 07:53 AM   #7
Uncle Scotty
Member#: 16200
OK buy Nates beans
Pakin.....did you READ the first post???? and then suggest what you did????
Bad juju.
Old 01-24-2005, 11:33 AM   #8
ImprezaVA
Member#: 32846
1998 Impreza L-SOLD
Arcadia Green
Post Another Crank Pulley Victim
A deep 6 pt impact socket, 1/2" breaker bar + pipe extension is the only way I could get it off my 4EAT. Shouldn't be a big deal on the manual tranny. I hate to recommend the "starter method," but do a search and take caution.
-Charles-
ImprezaVA is offline   Reply With Quote
Old 01-24-2005, 02:10 PM   #9
Pakin
Member#: 17315
MY95 Impreza 207C
MY05 Forester 257X
Yes.
Originally Posted by Uncle Scottie
Bad juju.
What is "juju"?
-paK +1
Old 01-25-2005, 12:19 PM   #10
toddbrowne
Member#: 79843
Yellow
-I had already tried that Pakin. Thx. Good socket, breaker bar and a GOOD pipe.
With that done and verified timing marks all lined up, any concensus on what would cause all cylinders to have low compression on an engine with less than 2k? 40,60,80,60. My guess is head gaskets. If so why?
Old 01-25-2005, 08:03 PM   #11
Uncle Scotty
Member#: 16200
OK buy Nates beans
Originally Posted by Pakin
What is "juju"?
-paK +1
http://dictionary.reference.com/search?q=%20juju
#2
Got it???
Old 01-26-2005, 09:46 AM   #12
Pakin
Member#: 17315
MY95 Impreza 207C
MY05 Forester 257X
kekeke!
Kinda. Is it like bad karma?
Thought it was an OT word or something where I would have to do teh search.
Unorthodox Lightweight Racing Crank Pulley petrakov08 1993 - 2001 Impreza Specific Parts 10 06-05-2010 02:06 AM
Crank Pulley Stuck- NOT Crank Pulley Bolt SubieNOVA Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 01-23-2008 12:36 PM
WTT Brand new gold cobb crank pulley for polished crank pulley IllNastyImpreza NESIC Private Classifieds 2 03-02-2007 05:08 PM
I will trade my perrin crank pulley for a stock crank pulley NITROS Mid West Subaru Owners Club Forum -- MWSOC 8 07-21-2006 10:51 AM
Perrin Crank Pulley Vs Unorthodox Racing Ultra S lightened underdrive crank pulley west_minist Normally Aspirated Powertrain 3 02-21-2005 11:56 PM
