Old 01-23-2005, 07:12 PM   #1
surfer5567
Member#: 61199
2002 wrx wagon
wrb, s2, blouch 2.5, 6spd
Default Need help with AP stg. 2. spiking and surging
ok i have a 05 wrx 5spd sedan with 14000 miles on it.
the mods are a custom bent 3in cat back and a JDM 4 to 3in bellmouth dp with a hollowed out cat and an access port. everything else is stock. Now i loaded the stage 2 cali base map like your supposed to then i loaded it in realtime just to make sure. Now since i have gon to stg 2 i get a very bad surging of power in 4th and 5th, and boost spike to about 18.3psi.
Here is the boost that i have read on the AP boost guage.
1st ~10psi
2nd ~15-16
3rd spike to 17.5 then surges between 14 and 17
4th 16 then spike and 18.1 then surge between 15 and 17
5th. this is the real bad one. from a 2500rpm pull up to 3000rpm i get 15psi drop to 9psi. then 3500rpm to 4500rpm i go from 10 to 16 to 13 to 18. i just stopped at 4500rpm because i knew something was wrong.
there is a definite surging and spiking going on. i had the totall exhaust intalled at a professional exhaust shop. there are zero leaks. idel is ok. any help will be greatly appreciated!. im going to call cobb tommarow but any help before then would be great.
thanks in advance!
bryan
surfer5567 is offline   Reply With Quote
Old 01-23-2005, 08:22 PM   #2
surfer5567
Member#: 61199
2002 wrx wagon
bump. really need help
Old 01-23-2005, 08:37 PM   #3
hippy
Member#: 36528
2002 Impreza Wrx
I know you posted your mods, but I just gotta ask. Did ya do the 3/16th mod?
peace
Old 01-23-2005, 09:25 PM   #4
surfer5567
Member#: 61199
2002 wrx wagon
no i didnt do it.
Old 01-24-2005, 11:37 AM   #5
surfer5567
Member#: 61199
2002 wrx wagon
Old 01-24-2005, 02:26 PM   #6
fasterthanrayswrx
Member#: 48672
2005 Subaru
WRX
How did the car drive before you loaded the ap? I would call cobb and ask them about it.
fasterthanrayswrx is offline   Reply With Quote
Old 01-24-2005, 03:48 PM   #7
Brahmzy
Member#: 3293
'14 FXT-T
'15 XTERRA PRO-4X
Are you sure you don't have an intake?
Old 01-24-2005, 04:10 PM   #8
swift2fly
Member#: 70810
07 impreza STi
Jizz White.facial anyone?
adjust your wastegate? but it sounds like symptoms of a 3/16" mod. or maybe you have a leak. try this..try the stage 2 1.12 as a base map and the stage cali map as a realtime. the updated 1.12 map has improved timing and is a lot smoother. ditch any intake.
swift2fly is offline   Reply With Quote
Old 01-24-2005, 04:13 PM   #9
darksands
Member#: 75122
2005 Impreza WRX
Crystal Gray
reset your ECU. Im going to post something in a bit about AP's so please contribute your info.
Peter
darksands is offline   Reply With Quote
Old 01-24-2005, 05:04 PM   #10
surfer5567
Member#: 61199
2002 wrx wagon
ok called cobb. they told me to reset my ecu and adjust the wastegate about a 1/8 of an inch. so i did so and now it works better. im getting a steady 15.5-16.1 in 3rd and about 17 in 4th and 5th. so for being in the learing fase for the ecu its doing better. ill give it a week and see how it goes.
thanks for the contributions and help, and darksands when i get a chance i will contribute to your post
thanks
bryan
Help with my STG 2 tuning Chp_Stix Western Canada 3 06-13-2006 10:51 AM
Modified intake with AP Stg 2? thejean AccessPort 2 04-12-2006 07:11 PM
Who is running a CAI with AP stg 2? BHawk Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 16 05-16-2005 12:28 AM
clearing cel's with AP stg 2 02wrbwrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-12-2005 03:58 PM
Need HELP with AP WRXed4good Engine Management & Tuning 0 06-27-2004 12:33 PM
