Old 01-24-2005, 03:21 AM   #1
SlowPoke00
Member#: 72361
2002 Impreza WRX
Hey ho Silver, away!!!
Exclamation Radiator Fans wont turn on
So heres the prob... The car runs fine when driving, but when idle, the car starts to overheat. And I think it's because my radiator fans wont turn on anymore. I'm pretty sure that the fuses are blown for the main and sub fan but, I was wondering... I just installed my JDM projectors and tested if they worked, but only tested the lights with the wires for the drive/signal light plugged in, with the active high beam, not connected... could this have caused the fuses for the fans to blow?
After I found out that the fans werent working, ofcourse I connected all the wires for the projectors, so all the lights (driving light, signal, high beam) were working. I just hope its nothing more serious than that
note: yeah, it was stupid to test the lights with the other wires not connected, no need to say it...
SlowPoke00 is offline   Reply With Quote
Old 01-24-2005, 03:07 PM   #2
SlowPoke00
Member#: 72361
2002 Impreza WRX
bump ^^
Old 01-24-2005, 10:33 PM   #3
don_xtc
Member#: 72378
3125 Impreza
Trying not to b0rk my car
....hmmm sounds like the thermostat went tits up. I recommend that you get that fix ASAP else this is what could happen..
http://forums.nasioc.com/forums/show...ght=thermostat
don_xtc is offline   Reply With Quote
Old 01-24-2005, 10:44 PM   #4
SlowPoke00
Member#: 72361
2002 Impreza WRX
but if my thermostat is messed up, why does my temps go back to normal when I'm driving? My temps only seem to rise when I'm idle, and I did notice before, during idle, that the fans would turn on every few mins, now, they just dont turn on at all.
Old 01-25-2005, 08:45 AM   #5
don_xtc
Member#: 72378
3125 Impreza
When you're driving the radiator coolant will be cooled down by air passing through and around the radiator, but when you are sitting idle there is no wind(especially if your fans are not turning on) to cool the radiator or engine for that matter and thus your engine will start to over heat. On another note I believe that the fans only turn on when you're idling, there is no need for the fans to be on when you're driving 100km/hr down the highway. Anyways it's the t-stat that regulates the fans and if the t-stat is bad then it can't tell if the engine is overheating or not and thus it won't turn on the fans.
HVAC Fan wont turn on after gauge install HighAspirations Electrical & Lighting 14 07-28-2008 05:52 PM
fan wont turn on? kemosabe Alaskan Impreza Club Forum -- AKIC 10 04-20-2007 01:53 AM
Radiator fans wont kick on chokin Service & Maintenance 8 04-08-2007 12:58 AM
Radiator fans not turning on dan avoN7 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 01-23-2006 12:29 PM
Car overheating & radiator fans not turning on SlowPoke00 Service & Maintenance 10 02-08-2005 02:19 AM
