Welcome to the North American Subaru Impreza Owners Club Friday March 6, 2015
Old 01-24-2005, 09:16 AM   #1
scooterforever
Member#: 55011
Default Rear differential oil fill and drain bolts, same size as the oil drain plug?
I haven't had a chance to actually check under the car (we just got dumped on with snow here in new england, and the garage is a little messy right now), but does anyone know what the size of the drain and fill bolts is on the rear differential?
Specifically, I am wondering if they are the same size as the engine oil drain plug, they look about that size. Reason I am asking is I am contemplating putting a rear differential temp sender in place, and... if they are the same size then I'll just use the temp/pressure sender bushing you can buy for $8 at subaruwrxparts.com.
Thanks,
scooter
scooterforever is offline   Reply With Quote
Old 01-24-2005, 11:32 AM   #2
Jyik40
Member#: 48540
2005 Spec-V
Sapphire Blue
The differential plugs are tapered threads. The engine oil drain plug will not fit in to the same thread.
Jay
Jyik40 is offline   Reply With Quote
Old 01-24-2005, 01:11 PM   #3
jac04
Member#: 49895
09 Forester
06 Legacy 2.5i Wagon
The engine oil drain plug has straight threads and relies on the crush washer for sealing. The differential plugs have tapered pipe threads.
jac04 is offline   Reply With Quote
Old 01-24-2005, 01:38 PM   #4
scooterforever
Member#: 55011
Thanks Jay and Jac --
I'll order a spare differential plug (probably the fill one, as I think the drain has a magnet on it) and drill/tap it. Thanks,
Scooter
Old 01-24-2005, 07:06 PM   #5
jac04
Member#: 49895
09 Forester
Scooter
Yes, the drain does have a magnet on it.
Stock STi DP same bolt pattern/size as WRX? goodolkyle Newbies & FAQs 1 06-23-2009 11:25 PM
anyone know the size of the tran drain plug? steven765 Baja Forum 4 01-06-2008 10:32 PM
02/03 fog lamps the same size as the jdm fogs? BIGSKYWRX Electrical & Lighting 3 02-19-2007 11:08 AM
are 2.2 pistons and 2.5 pistons the same size as far as bore goes? azn2nr Built Motor Discussion 9 11-08-2006 07:53 PM
Are the painted side skirts the same size as the plastic ones that my car came with? RyanRock Interior & Exterior Modification 5 05-13-2004 07:33 PM
