Old 01-24-2005, 08:43 AM   #1
ezatnova
Member#: 10877
2007 BMW 335 Coupe
Space Gray with Coral Red
Angry A/C not working
The other day in the snow, I had my air conditioning on to help defog the inside of the windshield. When I got out to scrape the windows, I heard the main fan kick on for about a second, then stop. This kept repeating about every 20 seconds. I didn't think much of it since it was so cold out, and I also didn't think much of the fact that the windshield inside really was not defogging. Now when I press the A/C button, NOTHING happens (except the lovely little green light). No idle change, no compressor surge, no sound of clicking on, nothing. Quite frustrating with 36500 miles on the car (I would argue warranty coverage on the milage alone, but I bought it in September 01, so they would probably say I'm over due to time). Is there any kind of test I can do to narrow down the problem? Fuses, electrical, etc? Does the main fan always kick on with the A/C, which I suppose it was doing the other day before it fried for good?
Thanks,
Jeff
btw, I did search and each time I tried I got 500 hits, with little relevance.
ezatnova is offline   Reply With Quote
Old 01-24-2005, 12:26 PM   #2
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
You may have a hole in the system which caused the freon to leak out. When the pressure is low, the A/C will not kick in (there is a low-pressure sensor). There are A/C shops that can pressure test the system nice and quickly.
cdvma is offline   Reply With Quote
Old 01-24-2005, 06:46 PM   #3
ezatnova
Member#: 10877
2007 BMW 335 Coupe
Default UPDATE - More info
I pressed in the shrader valve in the Low pressure line and it seemed like it had plenty of juice left. Also, here's specifically what I see going on now:
Press A/C button - sometimes A/C activates. If it does, I can feel the High pressure line get VERY hot VERY quickly. I don't know if this is normal. I've never held onto A/C lines while it's running before. Low line stays cool. In no more than 15 seconds, there is a little click, and the A/C shuts off. I swear there is a bit of an odor too. Not necessarily burning. I don't know what it is. The H line then begins to cool. If I press A/C again at this point, nothing happens, I have to wait a few minutes and it decides to start again randomly. I also checked the A/C fuse under the coin holder, and it is fine.
I am stumped!
ideas?
Old 01-24-2005, 07:07 PM   #4
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
We have a forum for this and 2.0 ain't it. Moving.....
Old 01-24-2005, 09:57 PM   #5
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
If it's cold enough outside the compressor won't run as a protective measure. That may be the problem, or there could really be something wrong. Unfortunately the middle of winter is not a good time to attempt to diagnose possible AC problems.
Old 01-25-2005, 09:07 AM   #6
ezatnova
Member#: 10877
2007 BMW 335 Coupe
Intersting... But, in my garage at 45 degrees, it shouldn't be an issue, right? The A/C does the same thing in there.
Old 02-01-2005, 10:22 PM   #7
ezatnova
Member#: 10877
2007 BMW 335 Coupe
Sigh, I just don't get it. The shop said there's nothing wrong with my A/C and it's not supposed to turn on in the winter. It doesn't seem right to me though. Even if I sit in my garage with the car running (garage door open...I'm not THAT dumb) it's like 50 in there, and I'll also turn the knob to full cold in case that matters...no A/C compressor action. It just sits there... I'm not convinced it's ok.
radio not working/keyless entry not working AndyDick Electrical & Lighting 8 08-07-2008 04:04 PM
Cobb forum registration does not work - Cobb does not appear to care one bit AC7880 General Community 10 12-05-2004 11:41 PM
do not click!! not work safe!! bunot Mid West Subaru Owners Club Forum -- MWSOC 6 10-17-2003 06:24 PM
Headlights: Right - Working, Left - Not working tatical Service & Maintenance 2 12-11-2001 01:31 PM
OT: Some pictures of what I work on when I am not working on my RS. paultg New England Impreza Club Forum -- NESIC 15 07-06-2001 05:48 AM
