Old 01-24-2005, 11:04 AM   #1
amelnikov
Member#: 9827
2002 WRX Wgn 292whp
Alex Performance
Default STI Injectors with stock ECU vXXXXX
Hi guys. I know this has beat to death but I just had a bright idea and I wanted to run it by some of the brighter minds on this forum. Some years back there was a question raised in the Turbo-Dodge community if larger injectors could be run with stock ecu ( map based). Someone decided to try to run the larger injectors with higher scaling map. So he ran a 2.5 bar map instead of stock 2 bar with was just about the same difference in % as the bigger injectors compared to stock. the results were very good. So I'm thinking, what if we take the same idea and apply to our MAF tube. Have a tube made up that is larger then stock by the same amount as the STI injector are larger then stock. Would that work?
Any constuctive suggestions are welcome.
Alex...
amelnikov is offline   Reply With Quote
Old 01-24-2005, 11:32 AM   #2
fliz
Member#: 30342
I'm going to guess no.
It would be nearly impossible to design a tube that flows the same percentage more air than the stock tube at all flow rates.
Just look at issues aftermarket intakes have trying to match flow rates with the stock intake using the same diameter piping.
But, would it be possible to alter the MAF output electronically to make it read lower?
fliz is offline   Reply With Quote
Old 01-24-2005, 07:03 PM   #3
driggity
Member#: 7453
2014 Scion FR-S
Hot Lava
There's also the issue that the ECU uses the MAF sensor for other things such as timing. If you're running a larger MAF tube the ECU will think that you're under less load than you actually are and will not run the appropriate timing. There was a thread about this in the 2.5L forum talking about the Perrin BigMAF and Perrin modified injectors. Plus engine management is a good thing.
driggity is offline   Reply With Quote
Old 01-25-2005, 09:36 AM   #4
beefyib123
Member#: 55811
in theory it would work. if you could add just the right % of air to match the fuel. i maybe wrong but i am not sure if the throttle body would flow that much air.
Interisting idea but not one that would work without FAR more effort than it would be worth
beefyib123 is offline   Reply With Quote
Old 01-26-2005, 09:25 PM   #5
amelnikov
Member#: 9827
2002 WRX Wgn 292whp
Alex Performance
So basically a S-AFC with linear curve.
That's whay I was thinking as far as timing goes. Though it would be interesting to see how much the timing is affected. And why wouldn't the trottle body flow the air? It does just fine for everyone with big MAF tubes. I'll have to check the 2.5L forum to see if anyone has actually tried this. It would be intersting to see what Clark and Gorge think about this...
Thanks guys.
Alex...
Sti injectors on Stock ECU tep Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 09-12-2005 06:16 AM
how will my WRX run on STi injectors w/stock ECU (no piggyback/reflash, etc) annointed Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 04-10-2004 09:14 AM
Sti Injectors w/ stock ECU salaki Engine Management & Tuning 6 04-18-2003 11:11 PM
330cc Injectors with stock ECU Elliot Normally Aspirated with bolt-on Forced Induction Powertrain 5 11-05-2002 06:39 AM
STI Injectors and Stock ECU Ryan23 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 24 07-25-2002 11:15 PM
