Mid West Subaru Owners Club
Go Back   NASIOC > NASIOC Chapters > Mid West Subaru Owners Club Forum -- MWSOC
Old 01-24-2005, 12:20 PM   #1
shukes24
Member#: 1052
you fought
the good fight?
Thumbs down Need advise about Subaru Extended Warranty and CEL's
Well,
I've been getting CEL's since the end of fall. The car has now 47k miles and came with the Subaru Extended Warranty for 5yr/60k miles. The first time I got the CEL it was said to be due to old software on the ECU. So Evanston Subaru did the reflash and it went away. Now the 2nd time around about a month ago I get it again and they now say it is due to the fact the car needs a valve adjustment. He wasn't sure if it would be covered under warranty so I said get back to me. 3 weeks later now he calls and says that the Subaru Rep says it is not covered under the warranty. I'm in a pickle now because 1) the Subaru Warranty is USELESS 2) the car drives ok but if I don't get it done and go for an emissions testing I fail 3) they want f'ing $900 for this "adjustment"
I would like to ask: a) can this actually cause a misfire code? b) anyone have ideas as to what might be the problem and what are the problems if I don't get this done c) those that have the 60k warranty, what is it good for?
This sucks, and this will most likely be the LAST Subaru I own.
What a bunch of bull****...
Sorry just venting...
Oh and the car has NO engine performance mods and I drive like a grandma
Nirmit
shukes24 is offline   Reply With Quote
Old 01-24-2005, 12:47 PM   #2
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
Curious why this would'nt be covered. I understood that brakes,clutch,fluids and a couple other things were all that was not covered.
I think you're getting your chain yanked. Pull out your copy of the warranty and see what's up.
Tim Sanderson is offline   Reply With Quote
Old 01-24-2005, 12:54 PM   #3
Yotsuya
Member#: 935
Jack Soo Fan Club
Find the code for the current CEL; maybe it's a symptom that doesn't require a valve job, which sounds like a nebulous "we don't know so we're going to do as much as we can charge" kind of fix. It reminds me of when Subaru replaced my parent's clutch slave and master cylinders when they lost pressure in the clutch. Five hours later the pressure was gone again; the clutch line had a leak. I wonder if SOA paid for the warranty work on that when a $25 part would have fixed it the first time.
Plus why would an adjustment not be under warranty? I was guessing the dealer wanted the work and figured you wouldn't kick if Subaru covered it.
Of course that's me being pessimistic...
Yotsuya is offline   Reply With Quote
Old 01-24-2005, 12:58 PM   #4
DoctorNick
Member#: 7022
heh, DC ITCA are
my rides
I would ask for a reason, they should have to give that to you at least. Really blows, but SOE is cheap bitches
DoctorNick is offline   Reply With Quote
Old 01-24-2005, 01:11 PM   #5
yo vanilla
Member#: 71903
11 Audi A4 6MTQ
13 Mazda CX-5
i wasn't aware that a valve adjustment on our engines would be considered a job that might need to be done at all. i can't think of any modern engines that would.
coming from a guy who works at car dealerships, and always gives the car manufacturere the benefit of the doubt when taking about warranty issues, SOA is full of it and their warranty practices regarding wrx's is worthless.
yo vanilla is offline   Reply With Quote
Old 01-24-2005, 01:36 PM   #6
Akirasoft
Member#: 2973
2015 X3 35i M-Sport
substitute SOA for SOE and you have your answer.
Akirasoft is offline   Reply With Quote
Old 01-24-2005, 02:57 PM   #7
shukes24
Member#: 1052
you fought
the good fight?
well i got off the phone with the warranty company and started a case. i also called the dealership and asked what the difference bewteen this CEL and the last time i had the same problem. he stated that its the technicians call. same code same everything, but this time its a $900 job only on 1 cylinder too (#4) the warranty place found the $900 tag funny too...
i asked if this was common...they said no. they deny and call it maintenance. typically new cars need a valve adjustment 100k miles or so...unless you own VTEC powa! i did not find any verbiage in the manual that a valve adjustment is required or part of the maintenance schedule (unless I'm blind).
Old 01-24-2005, 03:13 PM   #8
DoctorNick
Member#: 7022
heh, DC ITCA are
my rides
so are you gonna get it covered? ask what tecs you talked to. Lord knows I know them
Old 01-24-2005, 03:16 PM   #9
BrianH
Bing user
Member#: 44383
I thought that there was a TSB released for the valve adjustment? Perhaps hondaslayer can chime in on this?
BrianH is offline   Reply With Quote
Old 01-24-2005, 03:26 PM   #10
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
A "Valve Adjustment" in a DOHC motor requires replacing of shims in the heads. These are not wear items, and I don't see why SoA would not consider this part of the powertrain waranty. In an RS, they could come out of adjustment, but you can't lose adjustment in a DOHC car due to the fact that there IS no adjustment! These cars are set like crap from the factory, valvetrain-wise, so I wouldn't be surprised if it was too open to begin with.
What is the exact CEL code that it is throwing? Misfire (P0300, P0301?)
Old 01-24-2005, 03:51 PM   #11
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
it'd be a P0304 if it's a cylinder #4 misfire, btw i'm not sure how this wouldn't be covered because if it's NOT a valve adjustment issue(which in that car isn't supposed to be done till 100K) then it's a burned/carboned valve. I suggest running some top engine cleaner thru it or a Valvoline Synpower fuel system cleaner/decarboner...it's cheaper then a valve adjustment
Old 01-24-2005, 03:53 PM   #12
WRXVT
Member#: 17979
335i Blue
brakes, clutch etc are covered under 3/36
WRXVT is offline   Reply With Quote
Old 01-24-2005, 03:55 PM   #13
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
try again, 12mo/12k wear items, never covered under 3yr/36k unless they admit that there is a known problem with them
Old 01-24-2005, 04:47 PM   #14
DoctorNick
Member#: 7022
heh, DC ITCA are
my rides
I think the previous owner fuked up your car.
Old 01-24-2005, 07:02 PM   #15
shukes24
Member#: 1052
you fought
the good fight?
yep P0304...thanks jer i'll try the cleaner out.
neal, i doubt it was either myself or the previous owner
it just don't seem right...$900 i'll try and pull the code myself and see if its still there, because the lights gone away
Old 01-24-2005, 11:16 PM   #16
WRXVT
Member#: 17979
335i Blue
you try again. its 3/36 stated simply on www.subaru.com Look it up and learn something before being a jerk.
Old 01-24-2005, 11:19 PM   #17
DoctorNick
Member#: 7022
heh, DC ITCA are
my rides
Default oh nos !!1!
Old 01-24-2005, 11:32 PM   #18
WRXVT
Member#: 17979
335i Blue
Yeah the warranty is pretty good for wear items. Heck I even got a new battery replaced under warranty after 3 years because it was tested "low." I've also gotten a couple sets of wipers covered after 1/12... its a good policy that is stated clearly on their website and by my service manager, although I wouldn't be surprised if some subie dealers tried to skimp on it.
Old 01-25-2005, 12:04 AM   #19
Akirasoft
Member#: 2973
2015 X3 35i M-Sport
Actually, the wear item thing was changed recently jer. For example, in Paul's RS the wear items were covered as you stated. Was changed for 2002 model year IIRC.
Old 01-25-2005, 12:09 AM   #20
BrianH
Bing user
Member#: 44383
lol I haven't seen anyone call someone a jerk in a while.
nippleheads.
Old 01-25-2005, 12:47 AM   #21
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
That doesn't seem right... I thought they changed in 03-04 to that 3/36, but according to their site even the 01's have a 3/36 on wear items. I could've sworn that there was a TON of 02's that had a hard time getting their brakes covered after 12k... you remember those crappy front brakes that fell apart on so many people.
Old 01-25-2005, 01:31 AM   #22
tooocool49723
Member#: 67127
3.3 I <3/h8 my GF3
1.8-2.5-2.2-2.5-2.2-3.3
In any case, would this throw a misfire code?
tooocool49723 is offline   Reply With Quote
Old 01-25-2005, 01:40 AM   #23
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Well, my 02 manuals don't say anything about OBD-II codes, strangely, but my 00 manuals do. I looked through and they said to check everything from fuel pressure, injector, to spark plug, to the compression... but not a word about the valve clearance or listening for anything too loud.
I suppose if one really wanted to test the theory, they could dampen the knock sensor somehow, so that it didn't pick up any irregular noises, and then re-run the car through it's tests.
Old 01-25-2005, 07:47 AM   #24
WRXVT
Member#: 17979
335i Blue
nippleheads.
I save my serious insults for the interweb
Old 01-25-2005, 08:23 AM   #25
b4wantab
Member#: 21293
05 OB Black Bean
1969 W-30
Evanston does not rate the high in my book.
I have been able to call the 800 number and talk to a person not a machine. They seem to be very helpfull or at least they try.
I picked up the extended Gold warranty and am finding out that it is worthless. It does not cover rubber items, so if there is a piece of rubber anywhere on the item in question it is not covered. So says the dealer.
Anyway, lets us know what it happens and if contacting SOA directly gets you anywhere.
Peace,
Greg
b4wantab is offline   Reply With Quote
Anyone have a contact number for Subaru extended warranty refunds? Wraith Off-Topic 1 01-25-2005 01:03 PM
('93-'01) Anyone here have a non Subaru Extended Warranty? inurb Impreza Forum 5 03-04-2004 09:11 AM
Subaru Extended Warranty BritSti STi Forum Archive 2 06-10-2003 03:10 AM
