Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 01-24-2005, 03:10 PM   #1
jlee8196
Member#: 22211
Default Hydra Boost adjust. questions
On element tuning it says that when boost is not reach it goes to
PWM map4 load zone, Going from high load zone (100%) if boost is off target.
Each load zone is set by cycle duty on the boost controll.
My question is why would you not do a linear cycle duty proportional to load zone. 100 load = 100% cycle duty... 90 load = 90% cycle duty.. and so on.
jlee8196 is offline   Reply With Quote
Old 01-24-2005, 05:15 PM   #2
bboy
Member#: 56468
04 Improved STI
Dirty White
Because boost is not "on" in every load zone (low load = no boost) and up to the wastegate cracking open their is no reason to control boost.
Do you want to adjust something, or are you just trying to understand the logic of boost control?
Hydra boost control Rick539 Other Engine Management 1 10-16-2008 01:43 PM
Hydra Boost Control Problem qhatherly Other Engine Management 5 11-25-2005 09:19 PM
Boost adjustment /w Hydra jlee8196 Other Engine Management 4 01-13-2005 10:38 PM
Question for Boost Adjustability out of ECU Only... Dave Schotz Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 12-25-2004 10:04 PM
Hydra Auto tune question Veck Other Engine Management 7 09-29-2004 09:35 PM
