Old 01-24-2005, 02:32 PM   #1
wreckedWRX
Member#: 38419
Red
Default airbag light is on and no cruise control
A couple weeks ago my airbag light came on, 02 wrx, but when I shut the car off it went away. My cruise control also stopped working, but worked later that day. Yesterday it did it again, but now the airbag light is permanently on, and cruise is not working.
The car was in an accident, but the bags werent popped. I'm thinking clock spring. The horn still works. Is there any way to scan the airbag light? A regular scanner shows no codes.
thanks
Eric
wreckedWRX is offline   Reply With Quote
Old 01-24-2005, 06:34 PM   #2
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
Good bet on the clock spring.
Jay
Old 01-24-2005, 10:01 PM   #3
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
The airbag codes won't show up in the engine ECU. There is a procedure in the service manual to read out the codes by counting flashes of the airbag light while in a diagnostic mode.
Old 01-24-2005, 10:26 PM   #4
ljaviation
Member#: 42270
2003 A&P IA
ww.flyingleafaviation.com
I've done that procedure after installing my seats (airbag delete), It's an easy function to perform, there is a 3 wire harness behind the fuse box, 1 plug and 2 pins. You insert the pins as specified in the manual, and the airbag light will blink the code (also found in the manual). You then can reset the light. If I could post it for you, I would. Get the manuals if you don't have them, worth their cost, for just such an occasion
ljaviation is offline   Reply With Quote
Check engine light, VDC light is on, and cruise control light is flashing grimace09 Normally Aspirated Powertrain 7 08-09-2012 03:42 PM
Check engine light, VDC light is on, and cruise control and sport light is flashing Legacymun2k6 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 01-30-2010 12:47 PM
Airbag light is on, aftermarket seats, 4 airbag cords? subierider Interior & Exterior Modification 7 10-26-2008 05:00 PM
CEL and No Cruise Control? Bearkat Service & Maintenance 7 04-04-2006 02:05 PM
No horn, Cruise control's bad and my Airbag light is on? Paxtonb Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 07-04-2004 12:22 PM
