#1 |
Member#: 75122
SCIC
Vehicle:2005 Impreza WRX Crystal Gray |
Ive heard many people with problems about boost spike or high EGT's with AP's and I would like to have people post some information to help solve problems. Ill start first of course so please chip in.
Vehicle Type: MY'05 WRX Sedan Base Map: Stage 2 91 oct CALIF map Real Time Map: Stage 2 91 oct CALIF map Mods: Perrin Lightweight Crank Pulley, Perrin IC hoses, Helix CATTED DP, USDM STI Axleback, DC flex up-pipe. Boost @ WOT: ~14.5psi in 3rd-5th gear read with AP EGT: 1500 WOT in 4th and 5th going about 90+ Miles on car: approx. 6000 Problems: Low boost Reasons: Stock Catback with High flow catted DP (?) Solutions: ***Updated AP with 05 software and am hitting target boost.*** For all to copy and paste: Vehicle: Base Map: Real Time Map: Mods: Boost @ WOT: EGT: Miles on car: Problems: Reasons: Solutions: If there is anything else that may need to be here, please add them. If you have any solutions for your fellow NASIOC members, please PM them or address them in this forum. Thanks Peter
Last edited by darksands; 03-02-2005 at 08:15 PM. Reason: more comments to add/ Boost went up!/ Added Copy and Paste |
#2 |
Member#: 61199
Vehicle:2002 wrx wagon wrb, s2, blouch 2.5, 6spd |
05 wrx sedan 5spd
stg 2 91 octane stg 2 91 octane JDM(dont know name) dp with hollowed out cat, custom bent cat back. 10-18.1(5th gear pull from 2500rpm) boost spike and surging 14500 wastegate actuator arm out of adjustment called cobb and was told to reset ecu, reload stg 2 base and turn wastegate actuator arm about 1/8" tighter. boost is steady at 16.5-17 in 5th WOT. ecu is still learing so giving it about a week to work its self if. |
#3 |
Member#: 78738
Vehicle:2002 Impreza WRX Sedona Red |
Vehicle Type: MY'02 WRX Sedan
Base Map: Stage 1 93 oct map Real Time Map: Stage 1 93 oct map Mods: APS CAI, (HKS DP and Carbon-Ti coming in this week) Boost @ WOT: 14.7psi - 15.0psi read with AP in 3rd EGT: N/A Miles on car: approx. 43000 Problems: NONE! Can't wait for the HKS TBE to come in, we're gonna be rocking that stg2 with some fun! |
#4 |
Member#: 71078
Vehicle:2002 Wrx Sedan Wr Blue Pearl |
Vehick type: 02 (Automatic) Wrx sedan
Base Map:Stage 2 93 oct Real time:Economy mode 91 oct Mods: Hks TBE (Downpipe & Catback), Hks uppipe, Protorque converter, Speedmonkee grounding kit, and K&N filter. Boost @WOT: 16.0psi Miles on car: 48900 Problems: None I love the accessport very easy to use but I wish they would come out with maps for different turbos (SR's, FP's, and more) |
#5 |
Member#: 73471
SCIC
Vehicle:2004 WRX Stg2+some Blk melon launcher |
vechile:04 wrx 5mt
base: stg2 91 rt: stg2 91 mods: greddy evo2, helix up+dp, perrin ic hose boost:~16psi miles on car:~30000 problem: none so far ![]() |
#6 |
Member#: 72818
SCIC
Vehicle:2002 Bugeye EJ25 | FPGreen |
Base Map: Stage 2.5 91 oct map Real Time Map: Stage 2.5 91 oct map Mods: vf34, Helix dp, perrin up, pink injectors, walboro fuel pump, stock catback Boost @ WOT: ~12psi in 3rd, ~13psi 4th EGT: N/A Miles on car: approx. 41,000 Problems: Low boost Reasons: Cobb said to reflash base map, I did and still see low boost. Cobb says its a mechanical problem and to check all hoses & clamps. Everything looks ok & still seeing low boost. My stg 2.5 feels the same as my stg. 2 did! Solutions: ??? |
#7 |
Member#: 72560
SCIC
Vehicle:04 WRX (stg. II) java black prl |
off topic but i have a question. so i should set the base map as what ill be running? ...and what should the real time map be? could it be nothing? ill be running stage 2.. would i want a real time map being stock mode? thanks.
#8 | |
Member#: 73471
SCIC
#9 |
Member#: 72560
SCIC
thats exactly what cobb said to me.. i was just trying to get a 2nd opinion
#10 |
Member#: 77525
Vehicle:'02 GDA, PSM '93 FD, Red |
Vehicle Type: '02 WRX Sedan
Base Map: Stage 2 1.20 93 oct map Real Time Map: none Mods: Cobb catted dp, Borla Hush cat-back Boost @ WOT: ~14.5 psi in 1st, ~15 psi in 2nd, 16.5 psi in 3rd-5th EGT: N/A Miles on car: over 42,000 Problems: none |
#11 | |
Member#: 75234
Vehicle:2004 WRX Wagon with 07 STI 6-Speed Goodness! |
#12 |
Member#: 75122
SCIC
Im not gonna touch the HWG maps untill i get EGT Guage installed as well as something to detect knock. Low boost was attributed to the stock catback in addition to the catted DP. Im putting off the 3in catback till i can get more money for it.
#13 | |
Member#: 75234
#14 |
Member#: 3272
TXIC
Vehicle:2005 Legacy GT Camo |
Vehicle Type: MY02 WRX Wagon
Base Map: Stage 2.5 91 octane Real Time Map: Stage 2.5 91 octance Mods: MRT TBE with cat, STi v8 uppipe, VF34, STI pinks, Perrin Lightweight Crank Pulley, Perrin IC hoses Boost @ WOT: 17.5 psi @ 5800ft. altitude EGT: arounnd 800C at WOT Miles on car: 44,000 Problems: none |
#15 |
Member#: 25478
SCIC
Vehicle:2003 WRX Sport Wagon PSM |
Bump for a good thread.....keep them coming!!
#16 |
Member#: 32459
Vehicle:02 WRX VF34 Junior Tuned 301whp |
Base Map: Stage 2 93 octane Real Time Map: Stage 2 93 octance Mods: BPM GT TBE, Borla header, Perrin pulley, Samco I/C hoses, intake silencer removal, Nino uppipe Boost @ WOT: 15.7psi in 4th gear EGT: No EGT gauge Miles on car: 65,000 Problems: none |
#17 |
Member#: 13304
RMIC
Vehicle:2002 WRX WRB De Re Metallica |
Base Map: Stage 2 93 octane v1.20 Real Time Map: Stage 2 93 octance v1.20 Mods: Stromung 3" DP (div wg), OEM 3rd cat, Borla catback, gutted uppipe Boost @ WOT: 1.15 bar in 3rd gear, 1.17 bar in 4th & 5th gear EGT: 825 C at WOT Miles on car: 32,000 Problems: none Last edited by forced4; 01-25-2005 at 10:37 PM. Reason: typo |
#18 | |
Member#: 11411
SWIC
#19 |
Member#: 52212
Vehicle:2004 WRX 16g-4EAT Plays well with traffic |
Vehicle type: 04 (Automatic) Wrx sedan
Base Map:Stage 2 93 oct ver 1.20 Real time: Not explicitly loaded Mods: Cobb DP (catted), PDE UP, Hushback CB, Perrin IC hoses, Protorque converter, real tires Boost @WOT: 1.15 bar Miles on car: Just over 4,000 Problems: None I ran stage 1 for a while with just the catback, then added an uppipe, and finally a DP and a reflash to stage 2. I adjusted the wastegate arm just a tad to reduce the flutter I had after adding the DP and I did experience very minor spikes but the ECU learned around it pretty quick. Although I've had no "known" problems, I'm not running an EGT gauge or a knocklink (so every time I read a thread like this it leaves me wondering. . ). Consequently, I don't run it real hard. Last edited by Over-Draft; 01-27-2005 at 01:05 PM. |
#20 |
Member#: 23499
NESIC
Vehicle:2006 Saabaru Black |
Base Map: Stage 2 93 oct Real Time Map: Stage 2 93 oct Mods: Helix uppipe, bosal downpipe, universal borla turbo muffler , prodrive IC hose Boost @ WOT: little under 14psi read with VDO Mechanical boost guage T'd off the BOV line EGT: N/A Miles on car: almost 70k Problems: none |
#21 |
Member#: 75122
SCIC
Theres got ot be more people out there with AP's. morning bump.
#22 |
Member#: 35049
VIC
Vehicle:2011 Mercedes C63 OE Tune 538/500 |
Vehicle Type: 2003 WRX Sedan
Base Map: Stage 2 93 Octane Base map Real Time Map: NONE -- ECU Reflash (1.5 yrs ago) Mods: Catless UP/DP, Catback, GFB pulleys, Y-hose Boost @ WOT: ~ 1.1 bar from 2nd gear and up EGT: N/A Miles on car: approx. 35,000km's Problems: NONE Reasons: n/a Solutions: n/a 2-3 weeks: stage 2.5 ![]() |
#23 |
Member#: 39806
NWIC
Vehicle:2003 WRX BLK |
Base Map: Stage 2 93 Octane Base map Real Time Map: NONE Mods: Helix FTBE - No Cats Boost @ WOT: ~ 1.1 bar EGT: 1650F - I haven't been that high with the new map = 1550F Miles on car: approx. 30,000 Problems: Timing pulled Reasons: Helix silencer Solutions: Reset the ECU after pulling out the silencer. ![]() |
#24 |
Member#: 60566
SCIC
Vehicle:2002 WRX Unicorn 2001 Legacy L 2005 XT 5sp |
Vehicle Type: 2002 WRX Sedan
Base Map: Stage 2 93 Octane Base map/stx293 Real Time Map: Stage 2 93 Octane Base map/stx293 Mods: Catless UP hi-flocat DP Boost @ WOT: ~ 15.5 p.s.i. EGT: N/A Miles on car: approx. 67,000 Problems: NONE in 8 months extremeley happy |
#25 |
Member#: 49763
Vehicle:2004 WRX Jetzt mit 25% mehr Motor! |
Vehicle Type: 2004 WRX Sedan
Base Map: Stage 2 93 Octane Real Time Map: Stage 2 93 Octane Mods: 3" TBE (no cats) - catless uppipe Boost @ WOT: (17 psi @ 4000) - (14.5 psi @ 5000) - (10.9 psi @ 6000) - (9 psi @ 7000) Electronically controlled, this is the maximum boost the stock turbo will make above 5000 RPM A/F: (12.5:1 @ 4000) - (11.6:1 @ 5000) - (11.2 @ 6000) - (10.9 @ 7000) Miles on car: 50,000 (AP installed at 40,000) Problems: 1 spun rod bearing Complaints: I personally think there is no need to raise the stock rev limter. Would that have prevented me from spinning a bearing? I doubt it, but still... |
| Thread Tools | |
| Display Modes | |
| Building a Part# list for everyone...Please contribute... | wrx182 | Factory 2.0L Turbo Powertrain | 29 | 07-07-2009 09:02 AM |
| Tire noise is important to some so, Please contribute. Thanks! | Drew888 | Tire & Wheel | 6 | 04-15-2005 02:32 AM |
| Cheap quiet RCA's please? Experts, please contribute. | ebeck | Car Audio, Video & Security | 20 | 11-29-2004 01:22 PM |
| Please contribute to the stock turbo 12sec wrx | joe_white | Factory 2.0L Turbo Powertrain | 22 | 01-19-2003 08:08 PM |
