Old 01-24-2005, 06:00 PM   #1
burton1181
Member#: 79870
02 WRX
Subaru Stars Fuel pressure
Ok so here's my situation. We recently put in a VF22, Walbro fuel pump, and Sti Pinks on my 02 WRX. For some reason my Fuel Pressure isn't adjusting propperly. It is reading on my gauge at a little above 3bar which is correct. As the car boosts up, the pressure goes up a little but just bearly. At first I thought the gauge was messed up but we clamped the fuel intake hose and it jumped right up to 6bar, so the fuel pump is working, then we blew air into the back of the fpr at 1 bar and sure enough it went up on the gauge so the gauge isn't messed up. So we replaced the fpr and it didn't do anything there either. we hooked up a boost gauge to see if the pressure was goign up and it went up exactly as it should. So it has the pressure coming in and going out... I have no idea what I could check now... We used Ecutec and were able to push in enough fuel but we were only putting about 250 to the ground. PATHETIC! Any suggestions?
burton1181 is offline   Reply With Quote
Old 01-24-2005, 08:27 PM   #2
bboy
Member#: 56468
04 Improved STI
Dirty White
You have done everything I would do. If you are getting boost pressure to the FPR and fuel pressure is not rising, it's got to be the FPR since you have shown that the lines will hold to 6 bar.
You say you swapped the FPR, did you install it, or something else? (can't believe it's not an FPR issue).
When you checked that boost was getting to the FPR did you use the same line that runs to the FPR nipple? (wondering about leak in boost line)
Old 01-25-2005, 03:13 PM   #3
burton1181
Member#: 79870
02 WRX
We put a new stock FPR in thats what we can't understand. We used the same line that rant to the FPR. We tried pretty much everything. Spent like 4.5 hours at the dyno scratching our heads, while I was around cursing and other things. I think I might throw a new fuel filter in just for kicks, though I seriously doubt that it will be the problem. I figure it won't hurt.
Old 01-26-2005, 05:34 PM   #4
aatsi
Member#: 55820
hello boys!!! I,am from finland and not sure how to tell you this right!!!
I had the same problem in my legacy 200 turbo my94.
problem was in fuelpump(walbro 255 high pressure)!
Pump it self works right, but the "back kick" (hope it,s the right word) was wrong! You can see "back kick" when you get the fuel line out of the pump!
I don`t have it anymore in my fuel line! It works!!!!
Mean the part what keeps the pressure in fuel line, when engine is stopped!
hope you can make the boxer work!
aatsi is offline   Reply With Quote
gauging interest: defi link display, oil pressure, temp and fuel pressure hinduluv Private 'For Sale' Classifieds 15 11-16-2005 06:46 PM
Fuel pressure, Oil pressure, and Oil temp gauges that fit in a single din? annointed Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-23-2002 11:40 AM
Higher oil pressure, lower fuel pressure after turbo, FMIC install SFastWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 08-08-2002 07:12 AM
Fuel Pressure or Oil Pressure? krave Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 03-01-2002 11:59 AM
SVX Fuel Pressure Regulator Solved Idle Pressure Problem the Dabbler Normally Aspirated with bolt-on Forced Induction Powertrain 23 11-05-2001 09:20 PM
