Old 01-24-2005, 06:10 PM   #1
runnah
Member#: 77447
2000 RS
Salty
Default Urgent help Needed! Not Good Vibrations!
OK when I go between 40-60 mph the rear vibrates wicked bad. I checked the wheels and ells for excess snow and build up. I also checked for excess wear on the tires or rubbing on the body. There was nothing obvious when I looked under the car on each 4 tires. I think possibly its a blown bearing or maybe i bent some thing badly.
No what i think cause it was today I was slipping on snowy road a little nothing to fast, when I hit some dry pavement and the car jerked and skidded a little. I didn't notice until driving on the highway home.
Help me please I need to be able to drive to work tomorrow.
(edit I can take pictures of any area people may think the problem is coming from for closer analysis)
runnah is offline   Reply With Quote
Old 01-24-2005, 06:14 PM   #2
jetfan2207
Member#: 61950
2008 Outback
big blue wagon
Good question I was just about to ask the same exact thing.However, I was on the highway, and the steering wheel seems to vibrate. I pulled over and checked the wheels/tires. There was a lot of black snow built up between the wheel and the stock mudflaps. I cleaned it out and it seemed to help. but now everytime I hit a bump in the road I think something is wrong now. Could the built up snow cause this? By the way, I don't think it could be snow built up in the wheel since I have stock steelies with the hubcaps still on.
jetfan2207 is offline   Reply With Quote
Old 01-24-2005, 06:18 PM   #3
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
you need to take the wheels off and look on the inside of the wheels, you will probably find ice and snow frozen to the inside of the wheel.
Jay
munkis is offline   Reply With Quote
Old 01-24-2005, 06:18 PM   #4
runnah
Member#: 77447
2000 RS
Salty
Jay
I looked, no dice. Thanks tho
Old 01-24-2005, 07:21 PM   #5
kevinsUBARU
Member#: 2263
2012 Impreza Sport
how about frozen stuff on your rear axles?
kevinsUBARU is offline   Reply With Quote
Old 01-24-2005, 07:29 PM   #6
Nasiocks
Member#: 62023
2013 ST
You may have lost a weight on a wheel or you have a bent rim or you have snow in the wheel. I don't think ice would stay on the axle at 60mph.
I bent a wheel on my last car (Aluminun bends easy) and let it go for a while. Then when I finally replaced the wheel I had to replace the tire too because it was warped from the rim. That Sucks!! I below $400 just to get it back to normal.
Nasiocks is offline   Reply With Quote
Old 01-24-2005, 08:31 PM   #7
runnah
Member#: 77447
2000 RS
Salty
ziltch, I took it to the car wash and blasted off any bits of snow i could find on the under carriage. I then drove on the highwayh and had the same problem.
I bet since I have stockers they would bend easier then an aftermarket rim eh?
How would i be able to test that? Find a flat surface and use a level on the rim?
Im taking it to a shop tomorrow.. At least I will have an excuse to buy new rims!
Old 01-24-2005, 08:34 PM   #8
HondaH8er
Member#: 3097
2013 Ford Focus ST
Performance Blue
You still need to check for missing wheel weights. Take it someplace and get the wheels balanced, that will tell you if it's that or not.
HondaH8er is offline   Reply With Quote
Old 01-24-2005, 08:51 PM   #9
runnah
Member#: 77447
2000 RS
Salty
nope all 8 weights present and accounted for.
I probly will get it done tomroow.
Is there anything I would be able to see without taking things apart?
I shook all 4 wheels and nothing was loose.
The rear does sounds noisier over bumps so I hope it isn't the struts
Old 01-24-2005, 09:14 PM   #10
sanremors
Member#: 69160
i had the same thing happen to me today. i called the subaru service dept today and they said 8 other people called about the same thing. they said that there was some ice buildup and to put the car in a garage and let it thaw out. it worked.
sanremors is offline   Reply With Quote
Old 01-24-2005, 09:22 PM   #11
runnah
Member#: 77447
2000 RS
Salty
Sorry im poor and live in an aprtment so no garage
But I did clean it throughly at the car wash. Im hoping that you guys are right
Old 01-24-2005, 09:24 PM   #12
snowman4us
Member#: 21764
Some GDM V8,
JDM Flat 4 X2
its the snow that gets built up inside ur rims...
snowman4us is offline   Reply With Quote
Old 01-24-2005, 09:26 PM   #13
runnah
Member#: 77447
2000 RS
Salty
OK, I did CLEAN the rims, there is NO SNOW OR ICE on any of the 4 wheels.
but thanks anyways
Urgent! help needed Urgent! iamrazor Legacy Forum 20 01-02-2006 03:43 PM
Urgent Help Needed on Truck Flood ! Im'Pat'za Interior & Exterior Modification 3 04-01-2001 10:23 PM
Urgent help needed with 91 Acura Intake. munkis General Forum Archive 12 01-01-2001 03:37 PM
Urgent Help Needed for Buying Kumhos! VALENTA New England Impreza Club Forum -- NESIC 1 06-11-2000 11:37 PM
Urgent Help Needed about Kuhmo Tires VALENTA General Forum Archive 3 06-11-2000 01:52 PM
