Old 01-24-2005, 09:26 PM   #1
The Rusty Gear
Member#: 62293
2002 Impreza TS
Question Engine oil in air filter
Doing my 30K service and had some questions about my air filter. First off I found the hose to my PCV valve unconnected. I'm not sure If I somehow knocked it off while fooling around, or if it's been like that for a while but maybe that could explain what I saw on the Filter?
The first picture is the air filter coming from head on. You can see the black oily spot. The second picture, (showed up great with a flash) you can see oil seeping in throung the front and passenger sive (vents?) into the airbox.
Is this normal? What can be causing this?
I've also noticed a louder exhaust on hard acceleration (related to PCV not hooked up?)
Thanks from a first-poster!
The Rusty Gear is offline   Reply With Quote
Old 01-24-2005, 09:33 PM   #2
wrx05
Member#: 69032
2005 Legacy GT
Obsidian Black
You may want to cross ref this thread in the NA forum..
I imagine that the oil coming into the vent is not a good thing although a friend with a SVT Lightning did have oil in his Throttle body and Ford said that it was normal.. Just a guess that there is some sort of similarity..
wrx05 is offline   Reply With Quote
Old 01-25-2005, 04:10 PM   #3
awilson529
RIP
Member#: 38867
11 Mazda
There shouldnt be oil in your Subarus air box... And my Lightning never had oil in the tb
Adam
awilson529 is offline   Reply With Quote
Old 01-26-2005, 09:19 AM   #4
Bottom Feeder
Member#: 2808
Replace your PCV valve. Make sure you haven't overfilled the crankcase with oil.
Bottom Feeder is offline   Reply With Quote
Oil in Air Filter cn4m Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 10-06-2009 10:11 AM
FS: Blitz LM high flow drop in air filter, Razo shift knob, bronze oil cap FCmaniac Tri-State Area Private Classifieds 1 02-08-2008 05:12 PM
Oil in air filter? RoadTrippin Normally Aspirated Powertrain 6 01-14-2008 09:24 PM
Oil in air filter? RoadTrippin Service & Maintenance 7 01-14-2008 07:36 PM
Engine oil in air filter The Rusty Gear Normally Aspirated Powertrain 11 02-10-2005 07:37 AM
