Old 01-24-2005, 09:43 PM   #1
xrays
Member#: 49152
Default my left headlight is out & it's not the bulb
One of the headlight on my 2001 Subaru Impreza is out and it's not the bulb. the connector that attaches to the bulb is loose and will only turn the bulb on if I jiggle it just right. What is this connector called? how much does it cost and how do i change it?
thanks
xrays is offline   Reply With Quote
Old 01-24-2005, 09:47 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Have you been using aftermarket bulbs by any chance? It's very common for such bulbs to cause damage to the connectors from excessive heat.
Replacement H4 connectors should be available at any parts store as a unit with wire pigtails that you splice into the harness after cutting off the old connector.
Old 01-24-2005, 09:51 PM   #3
xrays
Member#: 49152
no, i haven't been using aftermarket bulbs...at least not that I am aware of. my car is all stock.
where can i get replacement H4 connectors? and is this the entire plastic housing that sticks into the light bulb?
Old 01-24-2005, 10:33 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Yes this is the square plug that connects to the bulb.
Old 01-28-2005, 06:15 PM   #5
xrays
Member#: 49152
do you have a link to where i can buy this connector? I called the dealer and they wanted ~ $300 for the wiring harness. They told me they don't sell the connector separately. Pep Boys doesn't carry it.
Old 01-28-2005, 06:24 PM   #6
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
No link, but I'd be surprised if Pep Boys really didn't have this. If somehow they don't try the other major chain stores.
Forget the dealer, as you found out they do not sell the connectors independently of the harness.
Old 01-28-2005, 06:31 PM   #7
xrays
Member#: 49152
LOL I couldn't believe it either. I've called 2 different Pep Boys and they both said they don't carry it and recommended I go to a junkyard or dealer.
Old 01-28-2005, 06:38 PM   #8
xrays
Member#: 49152
Advanced Auto Parts and NAPA autoparts also don't carry this item. ARGGGGG
Old 01-28-2005, 07:03 PM   #9
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Are you sure you're asking for the right thing? I know I've seen this in stores.
Old 01-28-2005, 07:09 PM   #10
xrays
Member#: 49152
I asked for the H4 headlight pigtail or connector or the "thing that connects into the light bulb."
LOL
Old 01-28-2005, 07:16 PM   #11
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Ok, here's a link-
http://www.rallylights.com/hella/Connectors.asp
You just need to make sure that the H4 connectors listed are the proper gender (you need female ones).
Old 01-28-2005, 07:19 PM   #12
xrays
Member#: 49152
thanks. i'll try it out
Old 01-29-2005, 11:57 PM   #13
EvasionOfTruth
Member#: 13282
2007 FXT
WRB SPB Edition
Might as well upgrade while you are at it.
http://www.jegs.com/cgi-bin/ncommerc...10&prmenbr=361
Rhdude is using this and I haven't heard a complaint about them.
Buster
EvasionOfTruth is offline   Reply With Quote
airbag light on, please tell me it's because my passenger seat is out of the car hookedontronics Interior & Exterior Modification 9 10-08-2009 01:27 PM
Headlight is out, and it's not the bulb! bitterWRX Electrical & Lighting 7 01-22-2005 08:30 PM
My right headlight is out (2004), fuse or wiring? anzu Electrical & Lighting 2 05-25-2004 03:11 PM
SPOTTED: Red WRX outside of Rhonda in Exton, Your left headlight is out B.T.W. STR8OUT Tri-State Area Forum 1 10-03-2002 07:28 AM
107 & 113 and No...It's not the combination to my luggage. obyone Mid West Subaru Owners Club Forum -- MWSOC 7 08-27-2002 08:09 PM
