Old 01-25-2005, 01:45 AM   #1
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Default MY90-MY93 FWD Leggy Trans into MY99
So I was sitting at the light and going through the gears. I get into 5th and it gets stuck in there!!! So I had to heavily slip the clutch in 5th gear to get moving. The engine worked hard and I can smell the electronics burning underneth the hood when I got it home.
Reason....possibility of the shaving from the busted 2nd-to-3rd gear syncro or what not making it stuck.
Tempory fix IDEA
Purchase MY90-MY93 FWD tranny at local 'U pull R Parts' yard for $75, hoping that it'll still work well until I can get this tranny built. Looking at spending $100 total on NEW tranny fuild for the 'used' tranny.
I'm broke so this'll have to be the fix. FWD is fine...tire slippage is key to traction.
The my90-MY93 tranny DOES FIT into a my99 EJ block, DOES IT NOT?
I have the exedy stg1 clutch...
FuJi K is offline   Reply With Quote
Old 01-25-2005, 11:50 AM   #2
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
!!! wassup?
Old 01-25-2005, 01:01 PM   #3
jamesfacts
Member#: 51282
98 RS
black & blue from parking
Sure it does.
But, what electronics under the hood were burning?
jamesfacts is offline   Reply With Quote
Old 01-25-2005, 01:22 PM   #4
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Nothing was buring but it smelled like electronics overheating. The engine was working hard starting in 5th gear, that's all. I didn't want to keep slipping it at anythiung higher than 2500rpms, so that's why the engine was working hard.
Thanks for the comfirmation.
What was the deal about the number of bolts? 6 and 8?
Old 01-25-2005, 03:04 PM   #5
Scoobie Steve
Member#: 2289
1998 [email protected]
Subaru L Ver 6 STi Type R
The smell was your clutch. Impreza FWD transmissions use a smaller clutch and smaller front driveshaft stubs. I would guess the Legacy fwd to use a smaller clutch also. ANY EJ trans will bolt to ANY EJ engine, # of bolts doesnt matter. Also an awd Legacy transmission will require a Automatic propshaft for use in an Impreza.
Scoobie Steve is offline   Reply With Quote
Old 01-25-2005, 03:41 PM   #6
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
The smell wasn't the clutch. It smelt like the electronics or circuits overheating..... but anyway
Smaller clutch? I thought that you'd have to change the clutch only if the engine need it? So that means that the Turbo Legacy of the same year uses a smaller clutch too?
Old 01-25-2005, 05:41 PM   #7
Scoobie Steve
Member#: 2289
NO.... the fwd trans uses a smaller clutch. Clutches are matched to the transmission, not the engine. The legacy turbo uses a completly different style clutch and the turbo legacy never came with just fwd. The fwd trans is a light duty POS. IF you use the FWD trans you will need to change your clutch.
If you have burning electronics from just starting out in 5th gear then you have alot more serious problems then just your trans
Old 01-25-2005, 07:23 PM   #8
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Scoobie Steve:
Are the rear diffs of the Leggy and Impreza the same or not? The whole housing. Would my driveshaft be able to bolt up to the front of a Leggy rear diff?
Old 01-25-2005, 09:30 PM   #9
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
it will work but you will need
tranny
clutch
flywheel
presure plate
axels
trans mount
it would be 10000x better to find a 5 speed and matching rear diff
=its a bad idea .. don't dry shift any more
Old 01-25-2005, 10:44 PM   #10
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
Fuji,
I replied to your pm.
As for some of the comments brought up.......
The FWD axles will work just fine in the AWD transmission.....and for that matter are larger then the AWD front axles. The only exception I could see to this is if the 99 had a different axle setup then the older cars, but I highly doubt it.
As for the clutch issue. I can't say for certain about the impreza, but the first gen legacies used the exact same clutch size for AWD & FWD. I can give you the part #'s if you would like.
And the FWD tranny actually IMO is beefier then the AWD tranny. Less parts to send power through. The main shaft sends power directly to the drive pinion shaft, vs the AWD's setup which sends power to the driven shaft which sends it to the center diff & then to the drive pinion shaft & rear extension housing.
Josh
Legacy777 is offline   Reply With Quote
Old 01-25-2005, 11:08 PM   #11
Scoobie Steve
Member#: 2289
I did some research and Legacy777 is correct. The 1st gen legacy FWD uses the same size 8-7/8" disk 24 spine input shaft as an AWD. The FWD impreza trans uses the smaller 7-7/8" disk 21 spine input. I guess this make sense since the Impreza has the smaller 1.8l engine. So just make sure you get the FWD trans out of a legacy and not an Impreza and you will be fine.
Old 01-25-2005, 11:22 PM   #12
jamesfacts
Member#: 51282
98 RS
^^^ Yup.
Whenever I get around to it, I'll be converting my girlfriend's '91 FWD 4EAT wagon to a AWD 5MT... and I've been told by several people the FWD and AWD transmissions are interchangable.
Old 01-26-2005, 09:18 AM   #13
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Alrighty then!
I was reading through and I just noticed that I didn't put in that I was getting a tranny from a Legacy, sorry.
If you have the new style linkage, like I swapped over on my car, you can get the joint piece and put it on the FWD tranny, and it'll work with your shift linkage.
Josh,
Which joint piece are you referring to?
Thanks everyone!
Old 01-26-2005, 12:36 PM   #14
Legacy777
Member#: 4800
Old 01-26-2005, 12:44 PM   #15
subi_2.5rs
Member#: 67538
2003 impreza wrx
black/blue/purple
This should be "FuJi K" posting......
Do I have this joint peice on my linkage? OR do I have to purchase it? Is it on the FWD tranny?
The yard I'm going to lets me take the parts out myself, (local U Pull R Parts yard), so if it's on the FWD Leggy, I can get it OR just simply put that 'old' linkage in mine.
Yay, or nay?
subi_2.5rs is offline   Reply With Quote
Old 01-27-2005, 07:34 PM   #16
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
okies, I have the tranny dropped out in about 3 hours. Tomorrow I'll be searching for my FWD tranny. I'll be making measurments from engine to tranny mount to assure that I can use my stock tranny cross member.
I took a bunch of pics, but I guess you all know how it looks like anyway...
Old 01-27-2005, 09:09 PM   #17
Legacy777
Member#: 4800
The old 90-94 legacy joint piece is different then the newer ones in the pic
Old 01-27-2005, 10:14 PM   #18
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
I can just simply put my MY99 joint piece onto the Legacy tranny, ya?
Old 01-28-2005, 09:17 AM   #19
Legacy777
Member#: 4800
yeah you can do that
Old 01-30-2005, 09:46 AM   #20
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Update!
Leggy tranny purchased! Leggy tranny fits! We also took the shift linkage and shifter from the Leggy tranny along with the wiring that went to it, AND the FWD tranny mount.
There where things that we had to cross over from the MY99 tranny.
-Spring that pulls clutch lever back (I have pics)
-Speed sensor from cable to electronic (I have pics)
-Two other little sensors that goes on the side of the tranny (I have pics)
-Added my OBD II rear O2 sensor harness to it (I have pics)
I have to relearn how to drive it in FWD mode. Too much torque on start off and I get wheel spin. The gearing is a lot longer and at 5th [email protected], I'm spinning at 2350-2400rpms.
We also modified and rewelded the position of the Leggy shifter so it's WAY short in throw AND height (I have pics).
Thanks for the help, Josh!
Now I just have to worry about this...
http://www.mnsubaru.com/images/membe...ylinder1&4.jpg
.....after getting to drive my car for ONLY 15mins. This happened right after a flashing CEL (mis-firing). The engine died on me. It still cranks and starts up fine, no sounds of bents rods or anything.
Old 01-30-2005, 03:51 PM   #21
Legacy777
Member#: 4800
You're just not having good luck with the car are you?
Old 01-30-2005, 04:47 PM   #22
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
well...it's been a fun! The mis-firing occured and then the engine died. It'll start up but die for just a few seconds and then chokes and dies. Give it gas and it won't revv up.
I guess I have to not push the car so much...... it's leaking oil out of Cylinder #1 & #4. SO I don't know if it's blown pistons or what... if it is, then it's time for a STi shortblock. If it's not blown then I'd be dissapointed.... I'm actually not upset of this at all. I'm actually happy because I have an excuse for a better block!
WTB FWD 5spd trans for 93 Impreza 1.8 NJ PA DE MD NY aprezzal Private 'Wanted' Classifieds 0 04-12-2007 02:59 PM
pedal assembly for fwd cable trans conversion? josh...just josh Subaru Conversions 1 07-07-2006 07:10 PM
WTB: FWD manual trans and shift linkage josh...just josh Private 'Wanted' Classifieds 0 07-07-2006 06:11 PM
WTB: FWD 5speed Trans. Impreza L gr8wheels Private 'Wanted' Classifieds 3 03-17-2005 05:05 AM
WTB: FWD 5speed Trans. Impreza L gr8wheels South West Impreza Club Forum -- SWIC 0 03-16-2005 12:19 PM
