Old 01-25-2005, 03:23 AM   #1
nomadtw
Member#: 8037
1998 2.5RS - black
2iggpoints
Default dohc motor with sohc heads?
i have a 98 rs but am probably picking up a 2001 that was hit in the side for the front bumper but the engine is fine...
would it be worth my while to put the sohc heads, manifold, TB, map sensor etc into my car? i have 90k miles now and the head gaskets haven't blown yet i figure i'm on barrowed time
would i loose power gain power? would it be easier to just swap the entire motor out
i read that putting my heads on that block yeilds high compression so logic says that going the other way will loose compression and thereby a lot of power
would i be better off since i had it to just swap the motor get better gaskets and put my heads on it and run premium
how much more power does doing that add?
how much would i loose swapping the heads on my current engine?
turbo may or may not be in the future. obviously putting the lower comp heads on my block would be more ideal for turbo as would be the map...
i have a lot of questions and i'm hoping you guys have a lot of answers
nomadtw is offline   Reply With Quote
Old 01-25-2005, 09:22 AM   #2
Zephyr
Member#: 3362
2001 I've wired a
Few cars in my day
Unfortuneatly you can't plug the 01 ECM into the 98 harness.
Z
Zephyr is offline   Reply With Quote
Old 01-25-2005, 10:13 PM   #3
nomadtw
Member#: 8037
1998 2.5RS - black
2iggpoints
i can't? rly?
that's surprising i figured that wouldn't be an issue both being obd2 and all... hmm
so if i were to swap it would be more in my intrest to do ej20t or something then huh...
Old 01-25-2005, 11:26 PM   #4
YaZahX
Member#: 11932
1998 CW ITR
2006 NBP SI
the 98 is way old school as far as technology goes... i dot think u can do a 99 ecu either...
98 ECUs are not reflashable
and your better off keeping the dohc setup... too much work... search project frankenstien (there was a guy who put a sohc motor in a dohc car and used the dohc ecu)
YaZahX is offline   Reply With Quote
Old 01-26-2005, 02:15 AM   #5
nomadtw
Member#: 8037
1998 2.5RS - black
2iggpoints
what about keeping the rest and just swapping the heads loosing compression and turbo/supercharger
just changing to the lower comp sohc heads wouldn't require ecu change (i know a full out turbo would need standalone etc.)
STI block with SOHC heads sandman25 Engine/Power/Exhaust 4 02-13-2010 02:11 PM
sohc heads have higher rpm potential than dohc heads? sideways7 Built Motor Discussion 22 09-01-2006 07:49 PM
2.5 DOHC heads to 2.2 SOHC heads swap questions. sick1.8t Subaru Conversions 10 05-02-2006 03:45 AM
DOHC heads with SOHC block limeylight Normally Aspirated Powertrain 8 08-10-2005 03:43 PM
EJ257 block with SOHC heads. GrandpreRS Normally Aspirated with bolt-on Forced Induction Powertrain 8 07-27-2005 11:38 AM
