Old 01-25-2005, 08:44 AM   #1
NICOLA
Member#: 54638
2004 WRX
Default What is wrong with my 04 WRX?
:confused For the third consecutive time my car's dip stick was bone dry 2000km before the next scheduled oil change. Finally the dealer has aknowledged that there is a problem and are waiting to get a call back from the regional rep. They have informed me that they have replaced engines in cars with this problem at around 75,000km but never one as new as mine at 25,000km. I followed the break in period religiously and always had my oil changed at the dealership with regular dino oil (5w30). There are no leaks, yet I have not seen any blue smoke or black sludge on the inside of my tailpipes which are typical signs for cars that are burning oil. When i say my dipstick was dry I mean bone dry not a drop of oil on it all three occasions and I always check it while my car is parked on a flat surface first thing in the morning. Does anyone know what the problem might be? Will the dealer really replace my whole engine?
NICOLA is offline   Reply With Quote
Old 01-25-2005, 10:20 AM   #2
WRXVT
Member#: 17979
335i Blue
Well if you follow your maintenance schedule and have the documentation (and if you take it to the dealership for maintenance you should be golden), then you have little to worry about in terms of your powertrain warranty... unless you have mods. Is it really bone dry even after the car is warmed up???
WRXVT is offline   Reply With Quote
Old 01-25-2005, 11:04 AM   #3
NICOLA
Member#: 54638
2004 WRX
Yes bone dry, I have no mods and don't abuse my car (always allow it time to warm up and cool down). I guess i just got a lemon???
Old 01-25-2005, 11:21 AM   #4
SweetBaboo777
Member#: 47627
2004 WRX Wagon
Java Black Pearl
so where is all this oil going?
SweetBaboo777 is offline   Reply With Quote
Old 01-25-2005, 11:31 AM   #5
KC
Member#: 442
16 SS
00 S2000
Do you go to the same place to fill it? Are they not filling it fully after the oilchanges?
--kC
KC is offline   Reply With Quote
Old 01-25-2005, 11:40 AM   #6
Gfunk720
Member#: 42549
E92 M3 M\\\
VW Sportvagon Oilburner
Problem with this is that if you cant diagnose a problem, it is hard to try to fix. They will probably just recomend an oil consumption test, which will have you closely monitor your oil levels and usage.
How much is it down when you checked it? How long does it take to get to that point?(slow or rapid process)?
Gfunk720 is offline   Reply With Quote
Old 01-25-2005, 01:01 PM   #7
Ketchup
Member#: 62373
08 Mazdaspeed3
Sonlight Silver
Mine can go through a quart after about 2000 miles only if I run it hard.
They put the dye in my oil, checked my plugs, etc...all is OK.
When I first told them, they were concerned. Then I guess the found out that consumption is "normal"?
Ketchup is offline   Reply With Quote
Old 01-25-2005, 01:33 PM   #8
NICOLA
Member#: 54638
2004 WRX
Always the same place for oil changes, I always check in the parking lot before I leave to ensure that it is at the full mark. It takes around 3000km before it gets to this point. In other words there does not seem to be any oil loss for the first thousand or so kilometres.
Old 01-28-2005, 11:35 AM   #9
NICOLA
Member#: 54638
2004 WRX
WOw my thread really got moved, alomst couldn't find it at all. Anyways to keep those updated who were kind enough to chime in. The car is now in the shiop. they told me they were going to do a compression test on the engine to see if there was something wrong with any of the cylinders. They will also look into the clunking from my steering wheel and the free play in it when very cold outside. To top things off my sunroof started leaking and i have ice between my roof and headliner(that should be good for rust). I cant believe the luck I am having I went from a lemon civic SIR to a lemon WRX. I feel like selling this pos and getting a beater that way when things go wrong I wont be so heartbroken or feel so ripped off.
Old 01-28-2005, 01:49 PM   #10
WRXVT
Member#: 17979
335i Blue
sorry to hear about your misfortunes... hopefully it will turn out ok.
My paint looks dull- what is wrong with my car? thsiao Car Care & Detailing 36 05-19-2005 11:23 AM
Only [email protected] with 280who Dyno Dynamic, what is wrong with my car? sonicowrx03 Proven Power Bragging 41 06-24-2004 04:04 PM
What is wrong with my WRX !!! blitz01 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 37 03-09-2003 10:22 PM
Help, what is wrong with my rear brakes? scootr Brakes, Steering & Suspension 1 07-02-2002 08:53 AM
What is wrong with my WRX system part 2 WRXThis Car Audio, Video & Security 7 10-29-2001 03:37 AM
