Welcome to the North American Subaru Impreza Owners Club Sunday November 23, 2014
Old 01-25-2005, 12:07 PM   #1
joeyvaz
Member#: 33300
2003 WRX
Midnight Black
Default Cobb AP and CEL
I just installed a Cobb AP and have the Stage 2 93 Map as my base and real time. As soon as I flashed and turned the car on, I get a CEL. I run the code with the AP and it comes up P0102. I just looked up the code on this site and it says "P0102 Mass air flow sensor circuit low input "
What does this mean and will it cause any engine damage if I run the car while it has the code? BTW, I tried clering it, but it wouldn't go away. Also, the car doesn't seem to be running any differentl. Other than the smoothness and more power, all seems well. The CEL doesn't seem to be hampering me in any way.
PS
This is the 2nd AP I've had in my car. I had one for about a year and I sold it because I was goingto part out. I never did, so I bought another one. If I remember correctly, I was getting the same code back then.
Thank you,
Joe
joeyvaz is offline   Reply With Quote
Old 01-25-2005, 12:42 PM   #2
Chigliakus
Member#: 77525
'02 GDA, PSM
'93 FD, Red
You didn't list your mods, do you perhaps have an aftermarket intake? I'd say check all your intake tubing, ic hoses, etc. and maybe clean your MAF sensor. Cobb advises against using any aftermarket intake with their stg2 map.
Chigliakus is offline   Reply With Quote
Old 01-25-2005, 02:58 PM   #3
joeyvaz
Member#: 33300
2003 WRX
Midnight Black
Sorry about not listing the mods. They are Turbox XS UP/DP, Tanabe Hypermedallion catback. I had an Injen CAI when I had the first AP. I took it out when I sold the original AP. When I unmarried the 1st AP, my CEL went away. Yesterday I reflash my ECU and immediately I get this P0102 code. Yet the car seems to be running very strong. It's not stuttering, stalling, or anything.
I'm puzzled.
PS
What do you use to clean the MAF?
Old 01-25-2005, 03:17 PM   #4
Chigliakus
Member#: 77525
'02 GDA, PSM
'93 FD, Red
You can always call Cobb if you think the CEL is directly related to installing the AP.
As for cleaning the MAF:
http://forums.nasioc.com/forums/show...ight=maf+clean
Old 01-25-2005, 07:26 PM   #5
darkstarmoto
Member#: 44681
2011 WRX SWP Hatch
www.48hrs.info group lead
In addition to the link above about cleaning....if you go the spray cleaner route make sure it is "safe for sensors" and says so on the can. Some of the cheaper brands are not snesor freindly and are mostly designed for cleaning carbs and throttle bodies. Make sure you get a good brand name and it says it's safe for sensors.
darkstarmoto is offline   Reply With Quote
Old 01-25-2005, 11:13 PM   #6
JRSCCivic98
Member#: 67080
Put an AP on your car and you get a CEL... take it off and it goes away... Put another AP on and it comes back... humm
Why are you blaming the sensor? You think the AP code is any better at detecting a malfunctioning sensor then the OEM code is? Whatever your sensor is reporting seems to be out of range for what the AP code is expecting, so it's throwing a CEL.
JRSCCivic98 is offline   Reply With Quote
Performance and Looks! Cobb AP and 04-05 or 06-07 BlackTop Aero CF lip for under $1k RavSpec Engine Management 6 02-01-2010 10:34 PM
AP and CEL codes keoni004 AccessPort 5 10-31-2006 07:01 AM
FS: COBB AP and Stock 03 WRX parts ProSTI Private 'For Sale' Classifieds 4 12-28-2004 10:11 PM
Cobb AP and NE winter conditions question Jduke Engine Management & Tuning 6 12-08-2004 06:57 PM
Cobb AP and HKS TT DOHCammin Engine Management & Tuning 4 10-02-2004 03:57 AM
