Old 01-25-2005, 12:48 PM   #1
SubieFL
Member#: 1622
2000 Impreza 2.5 RS
Default Timing belt, etc. charges? (Urgent)
I drive alot so my 2000 2.5RS has a litle over 116,000 miles on it. Was procrastinating on getting timing belt done and finally brought it to shop yesterday.
This is what they are telling me it needs:
-timing belt
-accessory belts
-3 idler pulleys
-water pump
-tensioner
-seals/gaskets related to above stuff
Total comes out to a little over $1044
Is it possible that all of those ned to be replaced or am I probably getting ripped?
Is that an OK price for all of that?
Thanks
Jim
SubieFL is offline   Reply With Quote
Old 01-25-2005, 01:04 PM   #2
Julian
Member#: 1182
MY00 RS
BRP
I'd add coolant hoses and call it good. That's about what you SHOULD do, given your mileage. Some of those things are replaced during a timing belt change because you'd have to do 90% of the work over again if, say, your water pump craps out 10K later.
As to price, I don't know. Given you seem prone to skip maintenance intervals, I'd get it all done.
Julian is offline   Reply With Quote
Old 01-25-2005, 01:12 PM   #3
SubieFL
Member#: 1622
2000 Impreza 2.5 RS
OK, thanks for replying. I guess I'll get it all done, then.
Yeah, I am a procrastinator when it comes to getting the car serviced. I need to stop that.
I can do the coolant hoses on my own.
Old 01-25-2005, 06:12 PM   #4
Julian
Member#: 1182
MY00 RS
BRP
They're going to drain the coolant anyway...
One thing to check is that they aren't just adding up the book rate for each individual job. As I said, they're going to have to remove most of those parts anyway, so charging you book rate to change a water pump while charging you book rate to change a timing belt (et al.) would be a rip.
Old 01-25-2005, 06:46 PM   #5
SubieFL
Member#: 1622
2000 Impreza 2.5 RS
That makes sense. I kinda know the son of the owner so they said they tried to help me out by working with the labor charges. I'll check the charges to make sure they are not charging labor for each thing when I pay tomorrow.
Thank you
Old 01-26-2005, 12:27 AM   #6
Mike Wevrick
RIP 1/19/64 - 7/23/11
Member#: 24654
1957 Taggart Comet
atlasshruggedpart1.com
All of that is worth doing but the price seems pretty high. I suggest phoning around a bit and see if you can get a better price.
Mike Wevrick is offline   Reply With Quote
timing belt change in a 1.8 from 86 wilz02wrx Normally Aspirated Powertrain 4 06-03-2010 01:48 PM
Changing Timing Belt etc. What about Oil Pump? notjustforshow Newbies & FAQs 8 03-10-2010 05:24 PM
Misc Engine Access fs Madison, WI timing belt, tensioner, IC, Oil cooler etc etc meisen Engine/Power/Exhaust 11 03-01-2010 11:16 PM
NC: sti engine mounts, timing belt, etc realove Engine/Power/Exhaust 11 02-14-2008 08:54 PM
Timing belt, etc. service price quote...high? JonR Service & Maintenance 11 06-16-2006 12:35 PM
