Welcome to the North American Subaru Impreza Owners Club Friday July 31, 2015
Old 07-11-2001, 08:21 PM   #1
The Real Oaf
Member#: 6608
1996 Legacy Outback
Question Resetting timing belt tensioner!?!
As the thread says, How do I push the piston back into the housing?
This is for my 1996 2.2l motor.
Thanks in advance!
Paul
The Real Oaf is offline   Reply With Quote
Old 07-11-2001, 08:40 PM   #2
blaster88
Member#: 1109
1999 Suzuki Samurai
Blackish
Use a c-clamp - compress it S-L-O-W-L-Y - like maybe a half turn on the clamp every 15 seconds or so - take over 3 minutes or so to compress.
Use a small Allen wrench a a pin to hold it (but use the largest one that will fit in the hole).
If you don't, you will burst the membrane, it won't work, and you will have to spend $107 to get a new one.
Not that I've ever been so dumb to do that
blaster88 is offline   Reply With Quote
Old 07-11-2001, 08:41 PM   #3
The Real Oaf
Member#: 6608
1996 Legacy Outback
Thanks Blaster...back to the garage I go!!!
Will keep you posted!!
Paul
Old 07-11-2001, 09:01 PM   #4
bratmantlz
Member#: 3231
88 626 Turbo
white
you should post pics i am curious of what your doing eh.
Brat
bratmantlz is offline   Reply With Quote
Old 07-12-2001, 01:36 AM   #5
Avenger
Member#: 1234
He is just compressing a little piston that is either air filled or fluid filled. It is used to push the tensioner pully so that it put some tension onto the timing belt.
I used a vise to push it back, be carefull pulling off the little allen wrench key. I snapped one in half one time and had to pull it back off and fiddle around to get the borken half off.
Avenger is offline   Reply With Quote
Old 07-12-2001, 03:19 AM   #6
SkToBe
Ghost Mod
Member#: 1278
2001 RS
Hehe, I'll spill the beans...
Blaster88 speaks from experience... The first allen wrench was too thin and it bent so he took it out and re-compressed the piston... a little too quickly this time and it blew the seal. Heed Blaster's words, compress slowly!
SkToBe is offline   Reply With Quote
FS:Brand New OEM Timing Belt Tensioner & Timing Belt jsnm Engine/Power/Exhaust 5 04-06-2010 12:58 PM
FS: 2.5L dual cam timing belt, tensioner & tensioner adjuster $150 fornetti14 Legacy Specific Parts 0 06-20-2009 08:45 PM
Pay shop or DIY Timing Belt Tensioner and inner drive belt erikkellison Service & Maintenance 23 02-26-2005 02:28 AM
Timing Belt Tensioner Patrick L Mid West Subaru Owners Club Forum -- MWSOC 10 03-15-2002 05:48 PM
Timing belt tensioner holding tool? spshultz Service & Maintenance 1 12-09-2001 03:24 PM
