Old 01-25-2005, 05:09 PM   #1
chopstix
Member#: 56051
04 WRX 18g
Default 04foglights
Does anyone have instructions on how to change the fog lights on 04 wrx? Do i need to take off bumper or just that cover?
chopstix is offline   Reply With Quote
Old 01-25-2005, 06:00 PM   #2
satrya
Member#: 5887
2002 GDAA (bugeye)
797 (blaze yellow)
Afaik, just the cover. In case you don't have the user's manual, you can log on to mysubaru.com and register your VIN to access your model/year specific e-copy of the user manual.
satrya is offline   Reply With Quote
Old 01-25-2005, 06:39 PM   #3
kennyvb
Member#: 70234
MY86 BMW E30 325
SCIC/NWIC tranplant (-_-)
cover removal is not necessary.
you need to access the bulb from the back. take the two black plastic push-in tabs holding the splash shield from each side. pull down the splash shield. unspring the clip holding the bulb to the light housing. disconnect the wire to the bulb and remove the bulb. replace bulb.
the passenger side is more difficult to change if you haven't removed the intake resonator...there's very little room.
kennyvb is offline   Reply With Quote
