Welcome to the North American Subaru Impreza Owners Club Tuesday June 30, 2015
Old 01-25-2005, 05:12 PM   #1
elohdaeh78
Member#: 61395
2005 WRX
CGM
Default Heated seats turn off?
I posted this in the tri state forum and i found some mixed answers. I have a 05 wrx with the heated seats and i notice that no matter if its on the high or low setting after a few minutes they turn off, they will turn back on after a while, but i would like them to always stay on. My back gets nice and toasty and then they turn off and i get all cold again and have to sit there and wait for them to turn back on. Some people say theirs does this others say it doesn't. Please let me know what you guys think.
elohdaeh78 is offline   Reply With Quote
Old 01-26-2005, 10:03 AM   #2
skyhawk
Member#: 36255
04 WRB WRX
Drive 2 Work,Work 2 Drive
I have an 04 with the premium package and mine don't shut off until I turn them off with the switch. The owners manual even says to make sure to turn them off before you turn the ignition off because they can drain the battery. Don't know if they changed any between the 04 and the 05, but check your owners manual and if it mentions the part of turning them off before shutting off the ignition then take it to the dealer and have them check it out. You may have a broken element and when it heats up, it loses contact and turns itself off. Is the switch a momentary contact switch or is it a normal 3 position switch that you have to manually turn on or off? If it is a manual switch then it shouldn't be on a timer or anything and should stay on until you turn it off. If it is a momentary switch then it may be on a timer. I have a manual switch and mine doesn't turn off until I turn them off.
skyhawk is offline   Reply With Quote
Old 01-26-2005, 10:34 AM   #3
pezman04wrx
Member#: 66558
Mine stay on forever as well (04' WRX) ... Have to agree that something might be up ... Can't see that anything would have changed between 04' and 05', but ya never know ...
pezman04wrx is offline   Reply With Quote
Old 01-26-2005, 10:41 AM   #4
Yodaman
Member#: 78941
2005 WRX
CGM
Default Me Too!
Interesting, mine definetly turn off after 5-10 minutes and go through a cycle. Annoying as hell. I also have an '05, maybe they changed it. My brother has a Legacy GT 05 and it also does the same thing. My sister in law has a Ford Escape and it also cycles so I just thought it was normal, annoying but normal.
Ben
Yodaman is offline   Reply With Quote
Old 01-26-2005, 11:59 AM   #5
elohdaeh78
Member#: 61395
2005 WRX
CGM
What i have been gathering is that anyone with an 05 has this problem but nobody with the 04s have this problem, i wonder why they changed it.
Old 01-26-2005, 01:12 PM   #6
vorlon333
Member#: 72637
2004 WRX Stg. 2
I have an 04 and mine cycles, I thought it was a built in safty feature, something to keep the seats from overheating or something, I read my owners manual and I don't remember anything about it saying to turn them off or it will drain the battery, mine turn off when I turn the car off...maybe I need to check the manual again.
vorlon333 is offline   Reply With Quote
Old 01-27-2005, 10:36 AM   #7
skyhawk
Member#: 36255
04 WRB WRX
I'm sorry, I guess I was mistaken on what the owners manual says about turning it off. After all, it was over a year ago since I last read that section. Below is out of the owners manual for the 04:
When the vehicle’s interior is warmed enough or before you leave the vehicle,
be sure to turn the switch off.
NOTE
" Use of the seat heater for a long period of time while the engine is not running can cause battery discharge.
But anyway, It got cold enough last night that I got to use mine when I left work this morning and mine stayed on the whole time I had the switch turned on with no cycling. I also looked at the wiring diagram from the service manual and there is no timer relay or anything that would make it cycle on and off. Unless it is an integral part of the heater pads and not shown on the wiring diagram. I would say to call the dealer and talk to the service manager and ask him if it is normal for them to cycle on their own.
Old 01-28-2005, 03:07 AM   #8
SIMPFLY
Member#: 54794
2004 WRX Stock
210K+ miles as of Apr2015
my 04 cycles thru and doesn't "stay on". i figured it was a safety feature.
SIMPFLY is offline   Reply With Quote
Old 01-28-2005, 03:27 AM   #9
Dooley
Member#: 61076
2005 WRX OBP
TurboXS Up/TB Cobb stg2
mine stays on the whole time as far as i know unless it turns off everytime i look away and turns back on when i stare back.
oh yea, i have an 05
Dooley is offline   Reply With Quote
Old 01-28-2005, 08:25 AM   #10
elohdaeh78
Member#: 61395
2005 WRX
CGM
The light never turns off on the button the heat just turns off every 5 or 10 minutes then turns back on in 5 or 10 minutes.
Old 01-29-2005, 12:48 AM   #11
Scoobie Noobie
Member#: 65498
Well, my light stays on. I haven't noticed the heaters turning off but I don't use them much. They get very warm when I have used them.
I don't think yours should get cold even if they do cycle. If they do get cold, what's the point of having heated seats?
Scoobie Noobie is offline   Reply With Quote
Heated Seat Issue?!? maxpower_454 Interior & Exterior Modification 11 06-05-2010 08:05 AM
They decide to turn off the A/C, and turn on the heat 24 Off-Topic 8 11-06-2006 01:00 PM
does anyone know how 2 turn off seat beat ding?? my06 outback AliBenn Outback Forum 5 11-02-2006 12:58 PM
How could I turn off the seat belt alert? sububusti Newbies & FAQs 22 09-19-2006 10:41 AM
Heated Seats - Can you over-ride On/Off Cycling? WRXFiles Canada Region Forum 8 10-29-2002 07:14 AM
