Old 01-25-2005, 07:41 PM   #1
swift2fly
Member#: 70810
07 impreza STi
Jizz White.facial anyone?
Default modded WRX injectors vs. sti pinks
what do you guys prefer? they say that the modded wrx injectors get as big as 800cc and cheaper than the pinks. pros and cons please.
swift2fly is offline   Reply With Quote
Old 01-25-2005, 09:52 PM   #2
lowblow
Member#: 56902
2009 VW Jetta SE
Mod the stock ones and save yourself some money. They will flow anywhere from 740cc and 800cc. They will produce a nice cone shaped spray pattern as well. Just make sure you get an EM that can control the extra fuel for idle
lowblow is offline   Reply With Quote
Old 01-25-2005, 10:10 PM   #3
swift2fly
Member#: 70810
07 impreza STi
yea i just found out how much my stock injectors would flow if modded. i have the accessport and i'm going with the vf34 map which requires 565cc(sti pinks). i thought about modding mine until i found out how much it'll flow.
Old 01-25-2005, 10:55 PM   #4
el~sharko
Member#: 29735
2011 JSW TDI - DSG
2008 EVO X MR
just to warn you, not every everyone's car runs correctly w/ modded stock injectors.
el~sharko is offline   Reply With Quote
Old 01-25-2005, 11:08 PM   #5
pux888
Member#: 8356
02 STi swap
12 WRX limited
anyone know what could cause such a varation buy simply cutting off the caps. 740 -800 cc is pretty big.
pux888 is offline   Reply With Quote
Old 01-26-2005, 12:28 AM   #6
eastcoastbumps
Member#: 29201
BMW M3
Honda S2000x2
What kind of variation are you talking about? If you cut the caps off they'll all flow about the same. People have been getting various test results because of the various fuel pressures used while testing. The first test yeilded a flow rate of 740cc/min and some have added more fuel pressure and have gotten as high as 800+cc/min during other tests.
Pete
eastcoastbumps is offline   Reply With Quote
Old 01-26-2005, 02:14 PM   #7
pux888
Member#: 8356
02 STi swap
12 WRX limited
ok gotcha, i didnt realize it was bc of the extra pressure.
Old 01-26-2005, 02:26 PM   #8
lowblow
Member#: 56902
2009 VW Jetta SE
If you use the stock WRX 45 psi of fuel that the FPR produces, than you will see around 740cc, if you dimple the top and add 10 psi of pressure than you will see 800cc.
07 wrx Injectors aka STI Pinks 05Scooby Engine/Power/Exhaust 1 02-25-2009 08:46 AM
2007 wrx oem injectors vs sti pinks greenorange13 Newbies & FAQs 12 01-16-2009 06:05 PM
Need Help! I have a VF34 what injectors?? modded WRX 820cc of STI pinks..Street tuned Zerogravity Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 40 02-18-2008 10:58 PM
WTB, stock topfed WRX injectors. Or STi pinks. DoctorNick MWSOC Private Classifieds 3 04-12-2007 12:58 PM
Modded Stock Injectectors Vs. Sti Pinks Which Is Better wrx0001 Built Motor Discussion 2 04-10-2006 06:24 PM
