Old 01-25-2005, 08:13 PM   #1
zanderspeed
Member#: 72818
2002 Bugeye
EJ25 | FPGreen
Default Need Advice: COBB Stage 2.5 Boost Issues
Anyone out there ever experience low boost @ stg. 2.5? If so, how did you solve the problem?
I am only hitting 12psi in 3rd and 13psi in 4th WOT. I had the same issue @ stg. 2, although my boost was fine before I installed the Accessport (i.e. stock).
Cobb recommended to reflash with stg 2.5 base map and drive conservatively for 70 miles. I did, and see no difference in boost levels
Cobb then said it must be a mechanical problem and to look at the hoses and clamps and make sure they are ok. I checked and everything looks fine: no holes/cracks in the hoses, all clamps are tight, and the stock wastegate hose has the restrictor pill in the correct location.
Just looking for some ideas that may help me solve this frustrating problem. My stage 2.5 feels the same as my stage 2!!
Thanks
zanderspeed is offline   Reply With Quote
Old 01-25-2005, 10:15 PM   #2
swift2fly
Member#: 70810
07 impreza STi
Jizz White.facial anyone?
sell me your sti pink injectors.
swift2fly is offline   Reply With Quote
Old 01-25-2005, 11:22 PM   #3
zanderspeed
Member#: 72818
2002 Bugeye
EJ25 | FPGreen
lol... we gotta funny guy in here
Old 01-26-2005, 09:54 AM   #4
swift2fly
Member#: 70810
07 impreza STi
lol. sorry. i am going with 2.5 myself. i have a vf34 and pump ready. just need the pinks!
Old 01-27-2005, 02:34 PM   #5
zanderspeed
Member#: 72818
2002 Bugeye
EJ25 | FPGreen
...bump...
Old 01-28-2005, 09:17 PM   #6
hondaeater69
Member#: 60324
I've seen so many of these posts. . . .
I personally think it has to do with the restrictor pill. Try to get a smaller pill in the hose zander. Either drill out the one that's there, or try to find one with a bigger opening in it.
When I first had my vf34 put on, I would hit 21 psi with the vf34 hoses. I put the stock ones on, and only hit 12.
I called cobb and they sent their hose, and I hit target boost every day from that day on. Cobb has stated they have "tuned" around the stock hose, but it doesn't appear so.
Ask Cobb EXACTLY what does their hose consist of, and how can you get one (if not from them, how to make your own).
good luck.
Old 01-29-2005, 01:30 AM   #7
zanderspeed
Member#: 72818
2002 Bugeye
EJ25 | FPGreen
thanks for the advice... your experience sounds exactly what I'm going through. I'll definitely ask them about it.
Old 01-29-2005, 11:31 AM   #8
Kitt
Member#: 24621
2006 Legacy GT
2015 WRX STi
I also use the cobb restrictor and usually hit target boost, but ever since the cold weather I've been hitting 20psi. Yesterday at full boost my cel turned on, do you guys think thats what caused the cel to turn on?
Kitt is offline   Reply With Quote
Old 01-29-2005, 12:50 PM   #9
zanderspeed
Member#: 72818
2002 Bugeye
EJ25 | FPGreen
i don't know... but why don't you use the AP to check and see what code you threw?
Old 02-08-2005, 01:12 PM   #10
sandiegowrx
Member#: 41743
Does anyone know where to source a smaller sized restrictor pill?? I believe the stock is 1.2mm I'm looking for a 1.1mm or 1.0mm
sandiegowrx is offline   Reply With Quote
Old 02-09-2005, 08:23 AM   #11
anthonyrb98
Member#: 48307
02 bugeye
hbspeed tuned 18g sleeper
i'm having the exact same boost issues as this guy - max boost is around .93 bar.
anthonyrb98 is offline   Reply With Quote
Old 02-09-2005, 01:38 PM   #12
sandiegowrx
Member#: 41743
I think my wastegate is opening to soon. I am going to try a few smaller sized restrictor pills. lf that does not work, I am going to change out the spring in the wastegate actuator for something stronger.
Old 02-09-2005, 01:49 PM   #13
REDrum
Member#: 61536
WRX' 04Road02gravel
www.ToltecRally.com
tagged
REDrum is offline   Reply With Quote
Old 04-13-2005, 09:17 AM   #14
anthonyrb98
Member#: 48307
02 bugeye
still not hitting target boost
Old 04-13-2005, 11:07 AM   #15
psyber_0ptix
Member#: 60671
1992 Turbo Miata
351whp/344tq
? mine peaks at 19
psyber_0ptix is offline   Reply With Quote
Old 04-15-2005, 03:47 PM   #16
Soob02
Member#: 84200
2002 baja
Soob02 is offline   Reply With Quote
Old 04-15-2005, 03:48 PM   #17
Soob02
Member#: 84200
2002 baja
mine is in the mail. what is the deal with the accessport. Why all the probs. Is every one having this problem?
Old 04-15-2005, 04:17 PM   #18
derck_mullin
Member#: 51689
Nope...I've had mine for awhile and have never had any problems. I also have a Hyperflow TMIC and have had headers on the car and the AP had no problems with any of it. All cars are a little different...you're experiences may vary.
Derck
derck_mullin is offline   Reply With Quote
Old 04-15-2005, 11:18 PM   #19
fat angel
Member#: 81630
i had a problem of hitting only .093 on my setup and i went back and tightend all of my hoses and put a new hose on my bov. and i was hitting target pressure after that. i dont know if something was just lose or if the hose was the problem but it fixed what was wrong. i have a fmic on my setup also so i have a few more clamps.
fat angel is offline   Reply With Quote
Old 04-16-2005, 09:36 PM   #20
anthonyrb98
Member#: 48307
02 bugeye
i've seen mine peak at 1.13 bar, but only once. i can't see anything over 1.08 now. we'll see what happens once i put on my new turbo inlet hose and avo intercooler.
Old 04-17-2005, 09:54 PM   #21
BlackEyeII
Member#: 65140
2007 STI Limited#213
05 STI (rip) 03 WRX (rip)
Default Money...
Make sure you are not running any factory CATs.
If you are that could hurt. With the "Full" Scooby sport TBE 2.5" no cats or resonator I hit 1.2 bar in 3-5th pretty steadily.
With the factory resonator section put back in for sound reasons I can hit about 1.15-1.18 bar in the high gears.
Mods include and upPipe, and JDM STI IC (FYI)
Anyway blah blah, ditch the cats and free up the exhaust.
BlackEyeII is offline   Reply With Quote
Old 04-18-2005, 02:20 PM   #22
sandiegowrx
Member#: 41743
bump...
Old 04-18-2005, 02:22 PM   #23
zanderspeed
Member#: 72818
2002 Bugeye
EJ25 | FPGreen
I took the advice of both Cobb and Deadbolt, and used a smaller diamater restrictor pill to solve my low boost problem. However, my situation is a bit different than others since my low boost was attributed to the BlackHole wastegate port. I now hit between 16 and 16.5psi. I have no PTFB, boost spikes, or oscillating boost levels. It took awhile to find the "perfect" orifice size, but now the car is running great. I plan on getting a custom tune via AccessTUNER in the near future.
Cobb Stage 2.5 boost question WRexxer Engine Management & Tuning 4 06-17-2005 10:22 PM
WRX Cobb Stage 2.5 boost (93oct) Happy_Days Engine Management & Tuning 6 02-10-2005 08:12 PM
Cobb Stage 2.5 Boost spiking, Stock T Hoses! elhalisf Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 12-30-2004 03:27 PM
Cobb stage 2.5 issues. Raslian Engine Management & Tuning 8 09-09-2004 03:31 PM
cobb stage 2.5 ..low boost? x12oyx316x Engine Management & Tuning 15 08-10-2004 07:36 PM
