Notices
Old 01-25-2005, 09:33 PM   #1
2003Baja
Member#: 52985
Default Really weak when starting in cold
It seems that in really cold weather my battery seems almost DEAD. It actually took two tries to get the engine to crank over when it was -2 outside. Is this a comman thing with stock batteries? After driving around it starts with pleanty of power.
2003Baja is offline   Reply With Quote
Old 01-25-2005, 10:09 PM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
OK....one more time.....the stock batteries are junk....get rid of it at your first possible opportunity and your life will be easier 'cuz it can't die on ya and leave you stranded if you ****can it now.
Old 01-25-2005, 10:11 PM   #3
subaru mike
Member#: 30749
2002 wrx
i have an 02 just got a optima battery and it fixed the problem.
subaru mike is offline   Reply With Quote
Old 01-25-2005, 10:32 PM   #4
tooocool49723
Member#: 67127
3.3 I <3/h8 my GF3
1.8-2.5-2.2-2.5-2.2-3.3
I have an 00, I've had to deal with it actually NOT starting the car twice now.
First time, I wasn't late for anything, car wouldn't start, so I took mom's car to work, came home, still not working, I brought the battery inside, set it next to our wood burning stove for an hour, took it back out to the car and it started up first try (well, second, the ECU reset, so it stalled the first try). After this I realized the fluid level was low, so I topped it off w/ distilled H20 thinking that would get me through the winter.
Second time, first day back to school, had to get the neighbor to jump my car. ~5 mins late for class.
I'm getting an optima in the next 2 weeks.
EDIT: Both of these happened when the temp dropped below ~ -7f overnight. however, car is reluctant to start in anything below +10f
tooocool49723 is offline   Reply With Quote
Old 01-25-2005, 11:39 PM   #5
brunetmj
Member#: 8023
2004 2.5 RS
Another option, if you have access to a AC receptacle, is the battery warmer sold as a subaru accessory.They work quite well.
brunetmj is offline   Reply With Quote
Old 01-26-2005, 09:35 AM   #6
sha_zapple
Member#: 41012
1998 Legacy L
Stock battery here. deals fine with the Canadian winter (-30 celcius). Did you ever happen to do maintenance to the battery?
sha_zapple is offline   Reply With Quote
Old 01-27-2005, 10:10 PM   #7
Uncle Scotty
Member#: 16200
OK buy Nates beans
..if the stock battery has been neglected to the point that most of them have, like almost not starting the car, adding water to it won't help for long.
Old 01-27-2005, 10:31 PM   #8
WRXVT
Member#: 17979
335i Blue
battery was replaced under warranty on my 02... it wasn't even dead yet.
WRXVT is offline   Reply With Quote
Old 01-28-2005, 04:15 AM   #9
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
my 51R size Interstate brand battery starts my STI (bigger pistons and more compression) better at cold temps than the 35 size stock battery (which is nearly twice the size) started my WRX.
Uncle Scotty is right - Stock battery is a junker.
nhluhr is offline   Reply With Quote
Rough starting in cold weather, MPG dropping Old_Lady_Driver Newbies & FAQs 2 02-09-2009 09:12 PM
Trouble starting in cold temp. (What temp does gas freeze?) kamil212 Normally Aspirated Powertrain 26 12-20-2005 05:42 PM
Subaru's Harder to start in cold Weather? vincent-h Newbies & FAQs 22 12-09-2005 05:31 PM
Trouble Starting in Cold with vishnu unichip Br0kWRX Engine Management & Tuning 16 07-19-2005 03:39 PM
Hard starting in cold weather?? PunksWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 03-06-2002 05:08 PM
