Go Back   NASIOC > NASIOC Subaru Models > Forester Forum
Old 07-11-2001, 10:37 PM   #1
Imprezard
Member#: 3016
CBA GH8
WR Blue
Question Engine temperature question
Where should the temp gauge indicate after driving about 40 km under a sunny day in July? Today I just noticed that mine is at about right in the middle.
I think it's like that all the time, but when I opened the door to get out, I felt this hot air came out from the bottom of the car... what's this about?
Imprezard is offline   Reply With Quote
Old 07-12-2001, 12:13 PM   #2
Ken S
Member#: 1895
05 Leg GT Ltd. W
Talking
My temp gauge seems to always be just below the mid-way point regardless of the outside temp. I was once stuck in bumper-to-bumper traffic for an hour in 105 degree weather with the A/C on and the needle didn't budge.
Ken
Ken S is offline   Reply With Quote
Old 07-12-2001, 02:59 PM   #3
ForesterPerformance
Member#: 5424
BRP STi Version 3
Type RA V-Ltd RHD
Same here. THat's the way it should be if everything is working ok. I believe that the Forester comes stock with a 200 or 205 degree thermostat. That will keep the coolant temperature as close to 200 (205?) degrees as it can. With no leaks or clogged radiator, that means it stays at 200 (205?) all day long, regardless of how hot or cold it is outside. It may fluctuate a few degrees up or down as the thermostat opens and closes, but you really won't notice on the gauge provided on the dash...
Now, if you want a few extra ponies, I read on a UK page somewhere that by changing the thermostat to a cooler one, the engine runs cooler and therefore gives a couple of extra horsepower. But not to go below 180 degrees or so, then you start actually losing power, because the combustion chambers get too cool to actually burn all of the fuel properly. This info probably works alot better in the turbocharged cars, but it may be worth a try. I plan to do it, but haven't got around to lcating the proper thermostat yet...
ForesterPerformance is offline   Reply With Quote
Engine Temperature Getting Hot MY00 BE Acejam2k Legacy Forum 9 08-28-2006 01:52 PM
where does the engine temperature reading come from? MY05 MrSaabaru Normally Aspirated Powertrain 1 08-15-2005 03:15 PM
99 Outback Engine Temperature brianecarlson Normally Aspirated Powertrain 7 07-27-2005 07:32 PM
engine temperature? NicEJ25 Electrical & Lighting 3 07-30-2004 03:43 PM
Engine Temperature Questions HRE | giulio Technical Forum Archive 2 06-05-2000 10:59 AM
Message Board Statistics All times are GMT -4. The time now is 09:51 AM.
