Welcome to the North American Subaru Impreza Owners Club Saturday March 28, 2015
Vancouver Impreza Club
Old 01-26-2005, 02:10 AM   #1
Lantec
Member#: 48685
2010 Prius
Default Is this the endlink I need?
I have a whiteline adjustable rear sway bar and is this the rear endlink I need in order to have the tighter settings?
Lantec is offline   Reply With Quote
Old 01-26-2005, 02:15 AM   #2
AllWheelDrift
Member#: 9191
2002 Impreza 2.5TS
Blue Ridge Pearl
You should be able to adjust it to all the settings with the stock endlinks. Those endlinks are supposed to make the bar take full effect sooner because they won't flex as much.
AllWheelDrift is offline   Reply With Quote
Old 01-26-2005, 02:21 AM   #3
Lantec
Member#: 48685
2010 Prius
wouldn't that snap my sway bar or little connecting links itself?
Old 01-26-2005, 02:32 AM   #4
AllWheelDrift
Member#: 9191
2002 Impreza 2.5TS
Blue Ridge Pearl
It certainly won't snap your swaybar. Some people say it can break the stock endlinks and/or the stock swaybar mounts. I'm running a Whiteline swaybar set to 22mm with stock endlinks and mounts and haven't had any issues.
Also, doing a bit of research, the whiteline links in the picture are the old design and people have had problems with them breaking.
The new ones look like this:
edit: Also, people are upgrading to the 04 swaybar mounts, but you have an 04 anyhow so you probably only need links if you're that paranoid about breaking one.
Old 01-26-2005, 03:22 AM   #5
mtnbkrcr
Member#: 5715
2001 2.5 RS
If you are going to upgrade your endlinks I would recommend the newer Whitelines. I had one of the old ones break on me. Good thing I noticed it before it fully snapped in two.
mtnbkrcr is offline   Reply With Quote
Old 01-26-2005, 10:48 AM   #6
steve
Member#: 4718
~ too
many to list
I'm running the new Whiteline style and they work well. I wouldn't trust that spindly thing in the pic you posted.
steve is offline   Reply With Quote
Old 01-26-2005, 12:17 PM   #7
Lantec
Member#: 48685
2010 Prius
Oh... eeks hehe..
but what if I set the sway bar to 26? cause I think its a 22-26mm sway bar....on max setting, would it snap the bar?
Old 01-26-2005, 12:19 PM   #8
tora
Member#: 5851
09 Forester XT
+ NA Miata
Your stock sway bar links should be fine, you really don't need aftermarket links. If you break a link, just get a used or new one, the cost is minimal and they work just dandy with your bar.
tora is offline   Reply With Quote
Old 01-26-2005, 02:53 PM   #9
-S-
Member#: 6979
I doubt you'll break the sway bar. It's hardly the weakest link there. Breaking the endlink and/or the mounts would be more of a concern I think.
And do you really need to set the bar at 26?
-S- is offline   Reply With Quote
Old 01-26-2005, 03:23 PM   #10
Lantec
Member#: 48685
2010 Prius
that's what I'm concern with... the endlinks or the mounts... sorry I didn't say it before, I forgot the name...even though I did ask about it my mind went
and no I don't need the 26mm setting...but I did use 24mm before so I was a tad concerned about those breaking.
I bought some LightWerkz headlights, is this the harness I need? Capt Crunch Electrical & Lighting 7 02-21-2007 02:30 PM
Need a 12X1.5 banjo bolt for a SBR20G is this the same as stock? Irishman Newbies & FAQs 3 06-25-2006 11:29 AM
Real quick, is this the Foglight cover I need??? loudaccord Interior & Exterior Modification 2 05-24-2006 11:21 AM
Is this the beginning of the end of the I-Club? LachlanXG Off-Topic 17 11-18-2002 07:57 PM
So is this the begining of the end of the I-Club? Hazdaz New England Impreza Club Forum -- NESIC 1 10-22-2002 05:40 PM
