Old 01-26-2005, 05:11 AM   #1
WhiteKnight
Member#: 56133
2004 Euro spec Sti
Black - Rotated gt3037s
Question What does Water injection change ?
Does it affect AFR's ?
For example i tuned my car for 11-1 AFR till redline and turn the WI on.
What does it change ?
Is there any link for explanation for the water injection system ?
WhiteKnight is offline   Reply With Quote
Old 01-26-2005, 06:18 AM   #2
wrx plus
Member#: 42253
2003 RWD WRX
Alcohol injected, WRB
There used to be a water injection forum at www.turboice.com, moderated by Aquamist guru Richard, but I think the name's been changed to www.waterinjectionforum.com
wrx plus is offline   Reply With Quote
Old 01-26-2005, 10:34 AM   #3
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
It doesn't change the AFR reading significantly but what you see is a large drop in EGT and a loss of power. Leaning out the AFR to restore EGTs, adding some ignition timing, and maybe a touch more boost and I usually net about 20 whp with WI.
Thanks,
Phil
www.elementtuning.com
Element Tuning is offline   Reply With Quote
Old 01-26-2005, 10:38 AM   #4
pezman04wrx
Member#: 66558
There are alot of good posts, as well as many links in this thread ... Hope it helps out ...http://forums.nasioc.com/forums/show...ater+injection
pezman04wrx is offline   Reply With Quote
Old 01-26-2005, 11:08 AM   #5
WhiteKnight
Member#: 56133
2004 Euro spec Sti
Thanks !
Old 01-26-2005, 02:44 PM   #6
SaabTuner
Member#: 67608
It also tends to require much more ignition timing to be effective; it delays the flame development angle.
The advantage of WI over excess fuel is that the fuel slows both the development and rapid-burn angles, whereas WI only slows the development angle. A slow rapid burn angle is highly inefficient.
Adrian~
SaabTuner is offline   Reply With Quote
What does water taste like? Schniz Off-Topic 60 01-26-2009 06:28 AM
What does an oil change cost you? skittles15 Off-Topic 50 03-17-2007 05:58 AM
what does alcohol injection do? sc00bywagon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 11-18-2005 10:01 AM
what is water injection? hangten93 Newbies & FAQs 4 05-26-2004 03:38 PM
what is water injection? WillReckXhop Newbies & FAQs 10 05-02-2001 01:47 PM
