Old 01-26-2005, 10:00 AM   #1
dlowman
Member#: 22998
2004 WRX STi
GT35R 572 whp 93/meth
Default hyrda and emmissions
simple questions really, can the hydra pass state emissions tests? I live in Ga. I know they hook up the odb and try to read codes. Will the hydra pass this kind of test and be blind to the diagnostics?
Dan
dlowman is offline   Reply With Quote
Old 01-26-2005, 10:13 AM   #2
offset
Member#: 32636
2004 Impreza STi
Silver/Silver
No, sorry to tell you this but the OBDII doesn't work through Hydra.
offset
offset is offline   Reply With Quote
Old 01-26-2005, 10:15 AM   #3
offset
Member#: 32636
2004 Impreza STi
Silver/Silver
Oh and I live in a part of Ohio where there is still emissions testing. If I really want to get out of it I can just get a letter from Subura stating that the production total on my car was a specific amount and present the letter to the DMV for Collector plates. At least in Ohio that works to avoid emmissions testing. Of course it is a little more detailed than that, but you get the idea.
offset
Old 01-26-2005, 11:26 AM   #4
subiesown
Member#: 53798
/not to hijack...
I was wondering a similar thing. Are there hacks for utec, ecutek or any others? Since these ecu's have been supposedly totally reverse engineered, was wondering if someone could implant code that would cause an auto pass within the obdii checking system... If not, what is this about limited vehicles qualifying for exemption? I have an 02, and will be tested soon, and wondering what my options are... Even if stock dp is replaced, that would seriously not go well with a tuned engine exepcting an aftermarket dp.
Thanks
subiesown is offline   Reply With Quote
Old 01-26-2005, 04:19 PM   #5
offset
Member#: 32636
2004 Impreza STi
Silver/Silver
Originally Posted by subiesown
/not to hijack...
Thanks
No hacks that I am aware of; mostly because it is probably against some federal laws to try and trick any of those places. As to limited vehicles, it is mostly all state based. You didn't mention your location so I can't help; but I can say if you are in Cali or Oregon you are just screwed anyway.
offset
Old 01-26-2005, 07:02 PM   #6
subiesown
Member#: 53798
I see what you are saying, but isn't against federal law to be removing working cats anyway? or is that state law? anyhoo... I'm in Arizona. Any info welcome
Old 01-26-2005, 07:32 PM   #7
StiDreams
Member#: 26315
07 Outback
Silver/Silver
It's against federal laws to remove a functioning cat from any road vehicle. The way the after market gets around this and sells you a catless exhaust is to label their product "off road use only". Now it’s on the buyer to break the law by choosing to install the product on a road car and use said car on the road. There’s no reasonable way for the aftermarket to say that there’s valid reason for an “off road use only” product to have a mechanism in their product whose sole purpose is to fool a smog testing facility into thinking that there’s a valid ECU in the car when in fact there is not. If they provided such a mechanism it would be as if they’re providing the facility to break the law. It would then not only be the end user that is breaking the law then. The authorities would probably come down even harder on them than the consumer. Not really a smart or viable business plan.
StiDreams is offline   Reply With Quote
Old 01-26-2005, 08:47 PM   #8
subiesown
Member#: 53798
Understandable... So, lets say you get an ECUtek reflash... when you go for emissions, you are supposed to put catted dp back on, flash back to stock, then test, then replace catless dp, then reflash? I see alot of people with reflashes, but I wondering how they get around emissions. If anyone could provide additional information regarding that, or get a vehicle to somehow be exempt in the state of AZ, please let me know!
Thanks
Old 01-26-2005, 10:43 PM   #9
StiDreams
Member#: 26315
07 Outback
Silver/Silver
I don't think there is a problem with the reflash prior to 05. Just as long as there is no CEL, all the long term parameters are tested, and the tune does not cause you to fail the sniffer the ODBII should work just as before. That is provided that there is not a visual inspection to go along with the sniffer. No smog station is going to or would even know what to look for in a reflashed ECU. If you have a visual you will have to reflash back for the stock equipment unless your reflash will pass with the stock stuff. The crux is that you won’t know until you either pass or fail.
For the 05 and beyond you have to concern yourself with CVN, CIN and VIN in your ECU. It looks like that the law makers are going to give the smog checkers the capability to check for a reflashed ECU. Take a peek here: http://forums.nasioc.com/forums/showthread.php?t=649636 . I’m not sure if Suby was able to get an exempt from that for 05.
Old 01-27-2005, 01:07 AM   #10
kenlee
Member#: 49341
I asked awhile back if the utec would pass smog and seemed to get a yes from other members on the board. I assume I'd have to disconnect the abc and any other obvious parts. I hope this is the case since I don't want to swap the turbo out again.
kenlee is offline   Reply With Quote
Help with emmission test and a mechanic JJD92 New England Impreza Club Forum -- NESIC 0 05-20-2009 02:04 PM
Hyrda EMS, AEM EMS, or upgrade to sti ecu/wiring harness 03SuBbYWrX Other Engine Management 3 11-27-2007 04:47 PM
(FS) SC: HYRDA EMS STAND ALONE!! (Almost New)!!!!!!!! Crewchief Engine/Power/Exhaust 0 10-18-2007 05:35 PM
Hyrda knock warning? kharris4 Other Engine Management 3 06-06-2007 09:56 PM
Cobb or other ECU reflash and emmissions? bowenx Engine Management & Tuning 7 06-16-2003 10:42 AM
