Welcome to the North American Subaru Impreza Owners Club Saturday May 23, 2015
Old 01-26-2005, 10:05 AM   #1
maxiav
Member#: 40413
2001 BRP RS-T EJ257
Link'd - 252WHP 274WTQ
Angry Blowing OIL THROUGH BOV
I'm blowing oil through my BOV. Its pissing me off. The valve cover hoses look oil free. Suggestions???
maxiav is offline   Reply With Quote
Old 01-26-2005, 10:26 AM   #2
8Complex
Member#: 922
04 FXT
Red
Reroute your PCV system and/or use a oil catch can.
Old 01-26-2005, 10:39 AM   #3
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
graham had this problem search for his name and track session
Old 01-26-2005, 11:08 AM   #4
Portly
Member#: 1197
1997 Impreza Wagon
Mystic Blue Pearl
http://forums.nasioc.com/forums/show...&highlight=pvc
The thread that White mentioned.
_Jeff
Portly is offline   Reply With Quote
Old 01-26-2005, 11:51 AM   #5
maxiav
Member#: 40413
2001 BRP RS-T EJ257
I changed my PCV valve... If my valve cover hoses are oil free... where is the oil coming from??? from the the block vent hose?...
Old 01-26-2005, 12:29 PM   #6
Rev1
Member#: 51240
08 Lexus IS350
Hence the reason for an oil catch can
Rev1 is offline   Reply With Quote
Old 01-26-2005, 02:31 PM   #7
maxiav
Member#: 40413
2001 BRP RS-T EJ257
Guess I'll make all the hose vents go through the catch can and see if that does it. If not, I'm blowing somewhere else
Old 01-26-2005, 06:56 PM   #8
ThuotRDX
Member#: 16106
1992 T3/T4 turbo SVX
with a 5 speed
check your turbo, it may be leaking. (this would be bad)
ThuotRDX is offline   Reply With Quote
Old 01-26-2005, 07:18 PM   #9
mysubie
Member#: 67475
2004 sti
wrb
I had this problem and ran a catch can but I will still leaking very badly into the catch can so I ended up doing a compression test and umm yet that was the end of that block.
mysubie is offline   Reply With Quote
Old 01-27-2005, 03:08 PM   #10
maxiav
Member#: 40413
2001 BRP RS-T EJ257
I did a compression test in the summer and it was perfect. Did a leakage test and the numbers below 8%.... I'm hoping its just a catchcan problem...
Old 01-27-2005, 03:26 PM   #11
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
Check the turbo outlet nozzle and inlet nozzle, if there's oil on the outlet and not the inlet you need a turbo rebuild.
speedyHAM is offline   Reply With Quote
Old 01-27-2005, 05:36 PM   #12
maxiav
Member#: 40413
2001 BRP RS-T EJ257
hoping for no rebuilds...how much is one??...is it better to just go with a new turbo?
Old 01-27-2005, 05:46 PM   #13
8Complex
Member#: 922
04 FXT
Red
Couple hundred bucks to rebuild a turbo... maybe $250-300. It really depends on if you like the turbo since you'll be about even for buying a newly rebuilt or rebuilding your current one.
My 02 bugeye blowing oil out the BOV brammowrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 08-10-2008 09:20 PM
oil through inlet into turbo? toutanje Newbies & FAQs 1 08-05-2008 05:34 PM
Flow rate of oil through turbocharger? Nixlimited Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 31 08-13-2007 09:49 AM
Should I be able to blow air through my FBC? Cyclops Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 07-06-2006 09:07 PM
blowing oil through a turbo? milkman Normally Aspirated with bolt-on Forced Induction Powertrain 20 06-25-2002 06:29 PM
