Old 01-26-2005, 11:03 AM   #1
bryan_johnson
Member#: 78987
Default Variable WRX fuel pump vs basic Impreza pump?
I have heard that the WRX uses a variable speed fuel pump that is controlled by a little fuel pump controller box. Older, basic imprezas had a regular fuel pump that always ran at the same speed. Has anyone used the fixed-speed pump setup with a WRX motor?
Thanks for any insight,
Bryan
bryan_johnson is offline   Reply With Quote
Old 01-26-2005, 11:09 AM   #2
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
yeah, you will run rich without the fuel pump controller
Old 01-26-2005, 12:38 PM   #3
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
I would assume the answer to this question is yes, but does the wrx have the same fuel pressure regulator setup as the older cars?
Does the stock fuel pressure regulator just not flow enough, so without the fuel pump controller, you run rich.....or is there some other sort of issues...
Legacy777 is offline   Reply With Quote
Old 01-26-2005, 05:34 PM   #4
bryan_johnson
Member#: 78987
Default WRX fuel pump controller with old fuel pump?
So, can you use an old fuel pump that came off a car with a fixed-rate pump with the WRX fuel pump controller?
/Bryan
Old 01-26-2005, 05:55 PM   #5
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
The fuel pump in non-turbo Subaru's are still variable speed, they are just controlled by the ECU instead of a separate controller.
Using the old fuel pump would not flow enough fuel to supply a WRX or STI engine.
speedyHAM is offline   Reply With Quote
Old 01-26-2005, 09:33 PM   #6
Legacy777
Member#: 4800
The older pumps are not variable speed. They are simply on/off. The ECU just controls whether the pump is on or off
This diagram is for the 90-94 legacies, and the 99 is exactly the same.
http://www.main.experiencetherave.co...lpumpdiag1.jpg
Old 01-27-2005, 12:51 AM   #7
Zephyr
Member#: 3362
2001 I've wired a
Few cars in my day
Exactly.
The FPC is not needed to run the car but it is a nice feature to have.
DO NOT RUN THE STOCK FUEL PUMP. It will not flow enough fuel. Either use a stock WRX pump or something bigger if you are planing on doing extensive power mods.
Z
Zephyr is offline   Reply With Quote
Old 01-27-2005, 01:49 AM   #8
Kotir
Member#: 17300
1993 Widebody Wagon
748whp e98
Are you sure it runs rich without the fuel pump controller?
The FPR still regulates pressure to the same psi the same no matter what. My understanding is that the fuel pressure remains constant and the flow of the pump is reduced with the fuel pump controller; to extend the life of the fuel pump.
-Tim
Kotir is offline   Reply With Quote
Old 01-27-2005, 04:17 AM   #9
AlucardR
Member#: 54213
Speaking of which..I need the FPC connector, I had mine manually wired in but I'm getting a constant CEL because of no connector..if anyone has one shoot me a pm.
AlucardR is offline   Reply With Quote
Old 01-27-2005, 08:28 AM   #10
Zephyr
Member#: 3362
2001 I've wired a
Few cars in my day
Make a harness for it using some female blade connectors and some shrink tubing. I've had to do that more than a few times. Other people have done that too.
Z
Old 01-27-2005, 09:52 AM   #11
Homemade WRX
Member#: 33782
96 bastard child
-Tim
sorry should have put run rich down low where all the fuel being pumped isn't needed but up top the lower flow pump wil run out of breath and not be flowing enough
Old 01-27-2005, 09:53 AM   #12
Homemade WRX
Member#: 33782
96 bastard child
that's what I did and have had no problems
Old 01-27-2005, 09:55 AM   #13
Zephyr
Member#: 3362
2001 I've wired a
Few cars in my day
Cause I told you to do it that way
Z
Old 01-31-2005, 10:24 AM   #14
bryan_johnson
Member#: 78987
Thanks for all the info. This helps a lot.
/Bryan
USDM STI Fuel Pump Controller vs USDM WRX Fuel Pump Controller Boeleni Subaru Conversions 8 11-06-2009 10:33 AM
03 wrx fuel rail vs. 05 sti fuel rail question cruzinWRX2 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 12-16-2007 03:08 PM
sti fuel pump vs. wrx pump vtboost Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-03-2007 11:23 PM
STi fuel pump vs. WRX fuel pump WRXVII Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 09-02-2005 08:05 PM
Do old WRX's have variable voltage fuel pumps? Matt Monson Subaru Conversions 3 09-07-2004 12:00 PM
