Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 01-26-2005, 02:04 PM   #1
stevepius
Member#: 75378
1999 Forester
Default Random misfires, all cylinders
I don't know if this really qualifies are engine management but it is engine related. For a while I have been getting cylinder misfires in my 02 wrx so it was hypothesized that becuase the car ran rich for a time that the plugs were fouled. Last night I replaced them with new NGK PFR7G-11 gapped to .30. Last night while backing up after the installation I got a cyl 3 misfire again but after I cleared it I went over 20 miles both freeway and city streets with nothing. This morning as I started it to let it warm up it threw 1,2,3 misfires. I cleared it out and drove 15 miles to school both freeway and city streets and didn't throw one again. The pattern I have noticed is that it misfire at low rpms, about 1500-200 and out of usually reverse or 2nd, today was the first time I saw it throw one at idle, but nonetheless it was on that RPM range. If anyone has any further suggestions they are greatly appreciated. I am thinking of cleaning out the engine with either fuel system clean or that stuff GM sells that gets sucked directly through the vacum line into the engine. The car is just under 30k miles and was running rich for about a month is my understanding before I bought it. I'm wondering if that didnt' mess up the 02 sensor, but I don't know if that would cause misfire. Thanks for any helps you can provide.
stevepius is offline   Reply With Quote
Old 01-26-2005, 04:36 PM   #2
Delicious Tuning
Member#: 1990
Hi,
1. Do you have any modifications to the car?
2. When was the last service you had on the car and how many miles ago?
3. How long has this problem persisted?
4. When you bought it used, did the car have problems then?
Cheers,
William T. Knose Jr.
Lead Programmer
I-Speed USA
www.i-speed.us
Delicious Tuning is offline   Reply With Quote
Old 01-26-2005, 04:58 PM   #3
stevepius
Member#: 75378
1999 Forester
Originally Posted by skywalker
Hi,
Cheers,
Lead Programmer
I-Speed USA
www.i-speed.us
1. PE1820 turbo, txs fmic, txs downpipe, txs exhaust, txs bov, ur 785 injectors, perrin intake, a-spec up-pipe, utec, scanmaster3, sti trans.
2. No idea on service, just got the car recently and only problem was bad wheel bearing getting done next week.
3. Problem has persisted since I have started driving it about 3 weeks ago, previous owner has CEL disabled.
4. When I bought it the car ran fine other than needing a tune.
all 4 all cylinder misfirer squirelieRS Service & Maintenance 2 10-07-2006 09:24 AM
Misfire On All Cylinders scoobysti05 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 08-17-2006 06:40 PM
Misfiring on all cylinders? Subaruski Service & Maintenance 10 07-05-2005 10:59 AM
stg 4 misfiring all 4 cylinders beauhawk Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 01-21-2005 06:08 AM
My WRX is misfiring all 4 cylinders, gurgling, backfiring, and smoking... tEkkGOD Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 03-25-2004 11:51 AM
