#1 |
Member#: 14970
BAIC
Vehicle:1997 GF8 multi |
Hey Guys,
Been doing a lot of research over the past couple years and am actually looking at my exact options I have to deal with. Swapping heads, ECU, turbo system onto an 100k engine isnt worth it when you can just drop a Spec C in. Now the questions start boiling down to which to choose, a V.7 or a V.8 (I really want twin-scroll w/ AVCS) I was told (somewhere around here) that a V.7 Spec C will "plug -in" and all I have to change are the wires for AVCS... how much of that is true? Im finding it hard to believe my USDM chasis/engine harness is the exact same, and will plug into a JDM V.7 Spec C ECU with the simple addition of 4 wires for AVCS. Please, can anyone give me a rundown... If I go with a V.8 transplant, how much wiring am I relistically having to do? Rich
#2 |
Member#: 13520
Vehicle:99rs ej207 spec-c its for sale |
wiring up the ver 7 and ver 8 is going to be pretty much the same. U use the wrx harness and buy an IAP performance avcs wiring kit off him and ur done. The ver8 has 1 extra sensor i forget which, not sure if its needed or not
#3 |
Member#: 1581
Vehicle:MY00 RS/STi7 MY01 RS Both Silverthorne |
It shouldn't be that hard to believe, they're the same chassis, same basic engine, the only real difference is the AVCS. I'm pretty sure you can bolt it in, swap the ECU's, add the AVCS harness, and you're pretty much done. Wish it was that easy for the GC's.
#4 | |
Member#: 14970
BAIC
I find that very hard to believe... just give me some feedback Rich |
#5 |
Member#: 1581
Well, if it helps, I have used two Ver. 7 ecu's and one Ver. 8 spec-c ecu on my Ver. 7 swap in my GC with Ver. 7 wiring. Even a US WRX ECU will plug into either harness AND run either engine.
| Thread Tools | |
| Display Modes | |
| Would you say these are v7 or v8 Spec-C RA springs? | DomozitoLK | Brakes, Steering & Suspension | 3 | 02-09-2008 07:01 PM |
| Spec C cams for V7 or V8 heads | sjl1614 | Private 'Wanted' Classifieds | 0 | 02-05-2006 09:46 PM |
| v7 or v8 STi Splitter WRX Intercooler Shroud | Panic | Factory 2.0L Turbo Powertrain | 3 | 09-10-2005 02:55 AM |
| will a new v7 or v8 give the wrx more torque? | toebotypera | Factory 2.0L Turbo Powertrain | 1 | 03-22-2005 01:26 AM |
| v7,or v8 heads on v7 shortblock???? | werkInProgress | Subaru Conversions | 2 | 01-19-2005 02:00 AM |
