Old 01-26-2005, 10:37 PM   #1
zomba_830
Member#: 55221
2002 WRX silver
Question Timed Trigger: what to use?
I'm trying to figure out a way to enable my remote starter to start my vehicle at a predetermined time (ie 5:00pm), and am thinking about modding a 12 volt alarm clock to achieve this (using the alarm to trigger the module). I would rather use a timed relay, but the only relays I've been able to locate only control duration of trigger, which is of no use to me.
Does anyone know of a relay or timer that is capable of triggering the remote start module a preset time(s)?
Any help will be appreciated.
zomba_830 is offline   Reply With Quote
Old 01-27-2005, 06:25 PM   #2
brunetmj
Member#: 8023
2004 2.5 RS
Are you sure yours can't do that presently? Many types have some feature that would allow it. Or at least a preset number of times (every two hours etc). Maybe even consider replacing it with one that can. Since all the wires are already in place the switch should not take long and there not that expensive. I have found this brand to be reliable and economical.
Plus you can check thier web site to make sure it has the features you want.
http://www.ultrastarters.com/
brunetmj is offline   Reply With Quote
Old 01-28-2005, 06:10 PM   #3
zomba_830
Member#: 55221
2002 WRX silver
My remote starter is equipped with the "cold weather mode" feature which starts the vehicle every 2 hours, however, I can't program it to start my car at 5:00 am for example, which is what I want it to do.
Almost all the remote start modules I've seen (including Ultrastarters), have the cold weather feature, but none can be programmed to start at a specific time of the day.
I guess I'll just use the modded alarm clock until I can locate a better part.
Thanks for the help.
Old 01-28-2005, 07:38 PM   #4
Caliber
Member#: 40199
2003 WRX
Platinum
I just did a search and found that Prestige has a system the will do a 24hr start which I guess means you start it one day at 5pm it will start again the next day at 5pm.
Here is the link to the manual http://cartoys.com/cartoy/pdfs/aps996_manual.pdf
Caliber is offline   Reply With Quote
Old 01-28-2005, 11:03 PM   #5
zomba_830
Member#: 55221
2002 WRX silver
The "24 hour start" feature is built into the transmitter, which means the transmitter has to be in range for the vehicle to start. One of the reasons I would like to preset a start time is because I'm not in range to start the car and getting into range is an inconvenience.
Thanks for the link.
Time to change tranny and rear diff fluid - what to use?? madmax02 Transmission (AT/MT) & Driveline 6 06-27-2008 01:51 PM
Used swaybar refinishing, what to use? Rock_Strongo Brakes, Steering & Suspension 5 11-03-2006 01:52 PM
what to use to upload to an ftp? GregBolby Off-Topic 13 03-26-2006 01:22 PM
What to use to clamp down hoses running to turbo inlet BlackoutWRX General Community 4 03-20-2006 03:36 PM
what to use to be able to post pics.. bratmantlz Newbies & FAQs 22 04-27-2001 05:19 AM
