#1 |
Member#: 67185
Vehicle:2007 Audi S4 4.2l V8 |
I installed my Greddy elec boost gauge and EGT tonight. Is the gauge supposed to read vacuum most of the time? when I accelerate it goes up to zero then when I punch it it goes up to near 1.0 bar. It also idles at vacuum which I believe is normal. Does this sound right to you?
#2 | |
Member#: 61006
you don't like it is on boost all the time don't you? |
#3 |
Member#: 60106
Vehicle:I eat pieces of ** like you for breakfast |
perfectly normal readings.
#4 |
Member#: 67185
ok thx for the replies. I was just making sure I did it right. OK so one more question. To install the egt probe you must have your manifold drilled to fit the piece in. Is that something I can do myself or should I take it to a machine shop? I have a tap and die kit.
#5 |
Member#: 60106
depends on how comfortable you feel about it. when i first got my car, i said no way i would do it. however, after much research (and a few trips over to scoobymods.com
), i'm now very confident i could do it without problems.my only problem now is a. finding the time to do it and b. the freezing weather here in pa. ![]() |
#6 |
Member#: 67185
So is the tap and die kit all I will need to mount the probe?
#7 |
Member#: 64466
Vehicle:05, STI on green |
yeah that should be all that you need.
#8 |
Member#: 60106
a drill press would be nice but not required. also drill slow and use cutting oil.
http://www.scoobymods.com/forums/showthread.php?t=3367 |
#9 |
Member#: 67185
thx for the link!
#10 | |
Member#: 60106
Heck, you may want to create an account anyway. Lots of great info over there... |
| Thread Tools | |
| Display Modes | |
| A thought I had...is this correct (2.0 2.2 and 2.5 having same block size) | kaisersouse | General Community | 3 | 08-01-2005 02:27 PM |
| STi: Is this correct? | fasterthanrayswrx | Tire & Wheel | 2 | 04-17-2005 09:47 PM |
| Is this correct engine air filter for STi? | 2dino | Factory 2.5L Turbo Powertrain | 12 | 04-25-2004 11:30 PM |
| Is this correct for Boost ? | waitandbleed92 | Factory 2.0L Turbo Powertrain | 3 | 04-15-2003 11:50 PM |
| Is this correct | WR-REX | Texas Impreza Club Forum -- TXIC | 4 | 07-01-2002 07:53 AM |
