Old 01-27-2005, 01:01 AM   #1
dl337j00
Member#: 58049
1990 Skyline GTR
Gunmetal Grey
Default Top-Mount Oil Cooler?
anyone ever tried? i mean in the stock location for the intercooler...
when you do a FMIC mod, is there enough space left under the hoodscoop for an oil cooler? not sure how much room that IC piping takes.
dl337j00 is offline   Reply With Quote
Old 01-27-2005, 01:15 AM   #2
dr_wheel
Member#: 60106
I eat pieces of
** like you for breakfast
here are a few fmic setups from member's on nasioc.
so yea... probably not a great idea. stick with this:
dr_wheel is offline   Reply With Quote
Old 01-27-2005, 01:17 AM   #3
STi_Guy04
Member#: 69461
2004 WRB/Sti
11.41 @ 123mph
nice pics... good camera to but i have no answer to your ???
STi_Guy04 is offline   Reply With Quote
Old 01-27-2005, 02:45 PM   #4
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
There was a thread asking this same question a while ago...
ah ha here it is
http://forums.nasioc.com/forums/showthread.php?t=650407
cdvma is offline   Reply With Quote
Old 01-27-2005, 02:52 PM   #5
Evil STI
Member#: 36792
2015 Z/28 (Vader)
Gold chains & meatballs
It's a good idea but I don't know if it would make the oil pump work harder being up THAT high. Generally you would want the oil cooler to be at least the same level or slightly higher than the oil pan.
Evil STI is offline   Reply With Quote
Old 01-27-2005, 02:59 PM   #6
2phless
Member#: 69343
1998 TransAm cnvrtbl
I was considering that as well. I got the cheaper oil cooler.. flexlite I think, and was going to attach it to my strut tower brace. I have the freedom designs STB that used to go right over top of the TMIC so it has big oval perfs in the top to let air through and plenty of clearance for the TXS FMIC.
Edit out a brainfart here...
My only problem is the plumbing and having to run it so close to the exhaust manifolds.
2phless is offline   Reply With Quote
Old 01-27-2005, 03:28 PM   #7
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
if someone does it lemme know
i was thinking about doing this as well
my piping gives me just enough room to do it
Old 01-27-2005, 09:31 PM   #8
CBRDSpeedfactory
Member#: 68255
ALL lots of fast 1s
mostly silver!
Default well...
behind the grille is a nice spot...
i am going to be working on one to go in the lower opening, incase u dont have a front mount....
like me...water/air
cb
CBRDSpeedfactory is offline   Reply With Quote
B-Line top-mount oil cooler installed DroppedClutch Water/Methanol Injection, Nitrous & Intercooler Cooling 23 05-30-2009 08:42 AM
top mount oil cooler setup shwoop_soobie Engine/Power/Exhaust 24 04-14-2009 11:10 AM
Top mount Oil cooler/tran cooler ColesSTi Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 08-31-2006 08:10 AM
Top mount oil cooler? midnightsti Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 15 08-14-2006 01:48 AM
Top Mounted Oil cooler stevo2234 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 12-16-2005 06:35 AM
