Welcome to the North American Subaru Impreza Owners Club Friday June 24, 2016
Old 01-27-2005, 03:41 AM   #1
edykh
Member#: 14246
Default Mobil 1 0W40?
I would like to know anyone using mobile1 0w40 for STI? I am using Amsoil 5w30 but it burn oil pertty much, so i want to try the mobile1 0w40.
edykh is offline   Reply With Quote
Old 01-27-2005, 03:59 AM   #2
kool168
Member#: 61006
i use motul 5W40... i think 0W40 is not thick enough for turbo cars?
kool168 is offline   Reply With Quote
Old 01-27-2005, 09:11 AM   #3
WolfPlayer
Member#: 65054
2005 STI (CGM)
Descooped / Dewinged
It's plenty thick ... plenty thick. FWIW, I am running the new 0w-30 Mobil 1 Racing Formulation oil.
http://www.mobil1.com/products/racing_formula.jsp
http://www.mobil.com/USA-English/Lub...cing_0W-30.asp
t
WolfPlayer is offline   Reply With Quote
Old 01-27-2005, 09:19 AM   #4
gerbs
Member#: 41597
i've used mobil1 0w40 since my first oil change, been through everything from -5F to 100F
best, oil, ever.
gerbs is offline   Reply With Quote
Old 01-27-2005, 09:24 AM   #5
MooreWRX
Member#: 6661
2004 STI
White/Silver
xW40 means they're both the same "thickness"
MooreWRX is offline   Reply With Quote
Old 01-27-2005, 09:42 AM   #6
WRB_in_my_veins
Member#: 66540
2004 WRX Sedan
2005 Legacy GT wagon
From the American Petroleum Institute at www.api.org
SAE Viscosity Grade
The center of the Donut shows the oil's SAE viscosity grade. Viscosity is a measure of an oil's flow characteristics, or thickness, at certain temperatures.
The low-temperature viscosity (the first number, 5W in a 5W-30 oil) indicates how quickly an engine will crank in winter and how well the oil will flow to lubricate critical engine parts at low temperatures. The lower the number the more easily the engine will start in cold weather.
The high-temperature viscosity (the second number, 30 in a 5W-30 oil) provides thickness, or body, for good lubrication at operating temperatures.
A multigrade oil (for example, SAE 5W-30) provides good flow capability for cold weather but still retains thickness for high-temperature lubrication.
A single grade oil (a single number in the center of the donut) is recommended for use under a much narrower set of temperature conditions than multigrade oils.
Operators should refer to their owner's manuals to select the proper viscosity oil for the ambient temperature and operating conditions at which the equipment will be used.
More information can be found at www.sae.org as well.
WRB_in_my_veins is offline   Reply With Quote
Old 01-27-2005, 10:37 PM   #7
FiKtIOn
Member#: 45796
2004 STi
Bacon and Eggs
Castrol Syntec 5w50
rockin'
FiKtIOn is offline   Reply With Quote
Old 01-27-2005, 10:55 PM   #8
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
When will you folks realize there is a forum for this?
Old 01-27-2005, 11:20 PM   #9
ajabobrut
Member#: 56726
2004 Baja Turbo
Regatta Red Pearl
This helps out on everyones # of posts made for a higher status.
Mobil 1 5w30
ajabobrut is offline   Reply With Quote
Old 01-29-2005, 07:45 AM   #10
BlackEyeII
Member#: 65140
2007 STI Limited#213
05 STI (rip) 03 WRX (rip)
Default Averages...
I can't back this up with documents (that I don't have to look up) but I can tell you that a 0-40w is on average thinner than a 5-40w
The ranges are cold weight vs Normal temp BUT there is some averaging involved as well IE... Or so I have read I believe in a FAQ about oil on this forum.
BlackEyeII is offline   Reply With Quote
mobil 1 0w40 + 15w50 CT26SupraTurbo Service & Maintenance 3 05-26-2010 12:13 AM
Mobil super 1000 oil = Mobil 1 ?? frederik Service & Maintenance 36 02-18-2009 12:18 AM
Mobil 1 0W40 Synthetic: Need Opinions markreda Service & Maintenance 29 11-16-2005 07:21 PM
Going from mobil 1 to regular Mobil ok? STi-BOD- Service & Maintenance 5 01-14-2005 03:32 PM
To Mobil 1... or not to Mobil 1... That is the Question (4200 mi) billmidd08 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 24 11-19-2003 05:05 AM
