Old 01-27-2005, 11:59 AM   #1
Shifty Eyes
Member#: 72126
2004 Sold WRX Wagon
Now 07 GT Leg Pearl
Default Black smoke = good?
I was told by someone that if I dont have a little bit of black smoke coming out of my exhaust at high acceleration that i'm not getting enough fuel. My car hasn't been tuned to this ecutek yet, but the previous owner and I have the same exact mods; just different brand names (the same quality). The only thing that he doesn't have is an aftermarket BOV.
I dont see any "black smoke" during heavy acceleration. So is my car running lean? She's running like a champ at 12-14psi of boost. Is the only way to check this a dyno tune?
Mods
ecutek
hks upp
hks down p
hks hi power exhaust
AVO shorty intake
perrin manual bc (running pretty close to stock boost)
AVO bov
thanks guys
-trev
Shifty Eyes is offline   Reply With Quote
Old 01-27-2005, 12:58 PM   #2
pezman04wrx
Member#: 66558
I wish I were qualified to give a known comment on this, but all I can guess is that your friend has no idea what the hell he is saying ... I can't see any reason that under any circumstances that it could possibly be a good thing to see smoke of any color coming out your exhaust ... You have a turbo, not a turbo diesel ... Diesel's smoke, turbos only smoke when they've been destroyed ... Like I said though, I'm not an expert by any means, so please, someone correct me if I'm wrong, and I'll gladly learn ...
pezman04wrx is offline   Reply With Quote
Old 01-27-2005, 01:08 PM   #3
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
Do you have any guages except for boost? I generally had some blackish smoke coming out of my exhuast during hard acceleration. It's not a rule that you have to have some though.
mbiker97 is offline   Reply With Quote
Old 01-27-2005, 01:14 PM   #4
Shifty Eyes
Member#: 72126
2004 Sold WRX Wagon
Now 07 GT Leg Pearl
Nope the only gauge that I have is boost. My car doesn't fart any smoke anytime, so I thought maybe my friend is right and I'm running her lean. I have another friend with a stage 4 rex and he's got black smoke coming out his exhaust on a hard acceleration, but hes also putting out around 300 ponies. He's got a laptop and he knows what his car is doing at all times so his car is healthy. So I dont know. God I hate being such a noob.
Old 01-27-2005, 01:28 PM   #5
Tgui
Member#: 44771
I think thats in reference to running rich. In general its safer to run on the rich side. When you run rich, a bit of smoke can be seen. At night though, you might also see flames.
-Eric-
Tgui is offline   Reply With Quote
Old 01-27-2005, 01:29 PM   #6
TyrannosaurusRex
Member#: 79046
2003 WRX
sadona red
well black smoke is better than white smoke
TyrannosaurusRex is offline   Reply With Quote
Old 01-27-2005, 01:36 PM   #7
blackwrecks
Member#: 46311
2004 Impreza WRX
JBP
Black smoke is caused by running rich without any cats. Turbo cars need to run rich under boost (which would be experienced under heavy acceleration) to cool the combustion process and prevent detonation. Detonation is a preignition of the Fuel before spark that causes increased cylinder pressures causing heavy wear. It can eventually blow your engine if the detonation (KNOCK) is excessive.
I wouldn't be concerned if you don't see black smoke, as it is usually an indicator that you are running too rich, which could foul your spark plugs, especially if you're running plugs that are a step or two colder than stock. In any event, instead of relying on black smoke, your best bet is to buy some gauges and/or a Data logger to monitor your tune and do some research so you understand what you're looking at.
Since you have an ECUtek flash already, DeltaDash would be a good choice (it'll allow you to make minor adjustments to your tune as well). If you're going for gauges, get an EGT gauge and a knock monitor; maybe an AFR gauge if you got a spot to fill.
blackwrecks is offline   Reply With Quote
Old 01-27-2005, 02:23 PM   #8
Shifty Eyes
Member#: 72126
2004 Sold WRX Wagon
Now 07 GT Leg Pearl
cooll thanks guys
Old 01-27-2005, 02:53 PM   #9
pezman04wrx
Member#: 66558
Learn something new every day ... Thanks for the info as well ...
Old 01-27-2005, 05:49 PM   #10
bboy
Member#: 56468
04 Improved STI
Dirty White
perfect comment
Read a lot more, the day's of tail pipe reads and spark plug assessment are pretty much over. Ohhhhh, but brings back memories.
Once "drove" a car to a service station (these don't exist anymore either) by pouring gasoline in the carburator because the points were failing. Now, picture, how does one do this. Well it took two people: a brave one, and a wheel man.
Old 01-27-2005, 09:44 PM   #11
engineerx
Member#: 42614
0405 WRX STi/S2000
AspenWhite/Silverstone
Originally Posted by bboy
perfect comment
LOL !!
I remember, sometimes my Toyota Corona wouldn't start I'd trickle some gas thru carb and that would do the trick!
engineerx is offline   Reply With Quote
Old 01-28-2005, 01:28 PM   #12
Physics Junkie
Member#: 65609
Black smoke = fuel
White smoke = coolant
Blue smoke = oh ****(oil)
Physics Junkie is offline   Reply With Quote
Old 01-28-2005, 07:45 PM   #13
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
Well black smoke is better than white smoke Just because you don't see black smoke it doesn't mean it's bad, and just because you do it doesn't mean it's good.
wrxdrvr is offline   Reply With Quote
Old 01-29-2005, 03:58 PM   #14
erice1984
Member#: 11778
1980 VWRabbit Diesel
w/AAZ Swap
black smoke - usually associated in completely OE cars is the driver of that car drives it really easy for a while then they floor it and big puff of black smoke comes out, carbon and a bunch of crap that builds up leaving the engine.
erice1984 is offline   Reply With Quote
Old 01-29-2005, 04:06 PM   #15
adeliciouspizza
Member#: 7844
05 STI CGM
a wrx with catless exhaust, intake, bov and mbc should generally have a noticeable bit of black smoke under wot in my experience. although as others have said you cant really judge anything just by that (unless the smoke is white or blue, in which case youve got problems).
adeliciouspizza is offline   Reply With Quote
Black smoke, no acceleration, no good :( WRXstyle Factory 2.0L Turbo Powertrain 13 08-18-2009 07:51 PM
Black smoke, BOV smoking, whats wrong!? GimpWRX Factory 2.0L Turbo Powertrain 3 04-04-2004 04:20 PM
Black Smoke? GQ Newbies & FAQs 1 02-18-2002 03:15 PM
Black Smoke when Accelng Hard? slowme Normally Aspirated Powertrain 8 01-12-2002 05:18 PM
black smoke...Why??? Keith Technical Forum Archive 5 07-13-2000 02:44 PM
Message Board Statistics All times are GMT -4. The time now is 08:43 AM.
