Old 01-27-2005, 01:07 PM   #1
MF-DIF
Member#: 62197
2002 PSM WRX
LG/Blurple FZ-09
Default New Cobb Stg.1 map better than the old version?
What are your guys thoughts? Does the newer version of the map run better on your car? I have an 04 WRX and am running the newest stg 1 93 map. I am seeing inconsistant boost from the new map. It rarely reaches about 14psi, usually dies around 11.7psi. When I had the older map on I constantly
hit 14psi. Should I give it more time to learn or just switch back to the old map? (been running it for 2day, older map hit 14psi instantly as soon as i reflashed.)
MF-DIF is offline   Reply With Quote
Old 01-27-2005, 06:58 PM   #2
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
I'd switch back to the old map if that was my car. But the new map works better than the old map on my car so i'm staying with the new map. Use whatever works best.Cars are different. thats why there's different maps.
wrxdrvr is offline   Reply With Quote
Old 01-28-2005, 06:00 PM   #3
MF-DIF
Member#: 62197
2002 PSM WRX
LG/Blurple FZ-09
Switched back, feels much stronger.
Slight Ticking on Cobb Stg 1 map chaoskingb Rocky Mountains Impreza Club Forum -- RMIC 11 11-18-2009 05:53 PM
Cobb stg 1 map compatible with aftermarket pulleys? xaznxeclipsex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 06-12-2008 03:11 AM
Sadly, the new Suzuki SX4 looks 10x better than the 08 WRX markman Off-Topic 16 08-20-2007 10:53 PM
Which version Cobb stg. 2 map is better? MF-DIF Engine Management & Tuning 4 03-05-2005 12:38 PM
Is the new 2005 stock head unit better than the 02-04 model? wayoutwest Car Audio, Video & Security 7 11-01-2004 06:17 PM
