Old 01-27-2005, 02:54 PM   #1
jacket03WRX
Member#: 62011
08 WRX 06 GTO
Rally Stuff Need some help I have some Proplems!!
Hey I have some problems with my car ok when I am in 1st grear. Well I am only getting 10psi of boost ????? I was getting 15 in all gears b-4 what could be causeing this all I have is a Intake and Cat-back Exhaust ! So if you guys can help me that would be great and the other thing that I am having problems with is when ever I hammer on my car my e-brake light comes on. It does this just at random times also. Its also been cold here latly and that is when started doing it. The 1st time it did it was when I unplugged my stock security sysetem so any help would be great thanks in advance
jacket03WRX is offline   Reply With Quote
Old 01-27-2005, 03:12 PM   #2
jacket03WRX
Member#: 62011
08 WRX 06 GTO
please someone anyone
Old 01-27-2005, 03:14 PM   #3
kapnkrunch2
Member#: 79104
take the intake off reset the ecu and see where that leaves you...
kapnkrunch2 is offline   Reply With Quote
Old 01-27-2005, 03:15 PM   #4
adeliciouspizza
Member#: 7844
05 STI CGM 450whp
05 FXT CGO Stock
oh noes!!!1 you have proplems!!1!!
adeliciouspizza is offline   Reply With Quote
Old 01-27-2005, 03:31 PM   #5
conker69
Member#: 59692
2005 Impreza WRX STi
WRB-Gold
When I floor my car a computer voice turns on and tells me to piss off, I'm tired. Then the brake light flashes and my car stalls. What should I do?
conker69 is offline   Reply With Quote
Old 01-27-2005, 03:36 PM   #6
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Your brake pads are about done and the boost thing is normal....or is that the other way around....
Old 01-27-2005, 04:02 PM   #7
imprezilization
Member#: 73471
2004 WRX Stg2+some
Blk melon launcher
imprezilization is offline   Reply With Quote
Old 01-27-2005, 09:46 PM   #8
wayoutwest
Member#: 14379
2007 Acura
gray
lol at 'proplems'
Good luck to ya!
wayoutwest is offline   Reply With Quote
Old 01-27-2005, 09:58 PM   #9
Beebs99
Member#: 73803
2008 4 Door WRX
I'm pretty sure the boost limit is set low in first gear by the factory ECU.
Beebs99 is offline   Reply With Quote
Old 01-27-2005, 10:11 PM   #10
Crawdads
Member#: 30907
SWP GDB-G
you have low brake fluid. the brake light comes on when the fluid level in the master cylinder is low.
one reason it might be low, is if your pads are worn out. worn out pads are further from the rotor surface, therfore it requires more fluid from the resivoir to make the pads reach the rotor. hence brake light. the fluid is sloshing around when you drive hard, triggering the low fluid sensor.
im pretty sure that boost is supposed to be limited in 1st gear.
Crawdads is offline   Reply With Quote
Need some help clearing up some 6-speed swap Q's! bigolrig Transmission (AT/MT) & Driveline 14 03-12-2010 11:28 AM
looking for some help tracking down some items cpages2 Off-Topic 6 10-22-2009 07:04 PM
Wife needs some Help. please spend some time. BREWPUBEAVER North West Impreza Club Forum -- NWIC 35 03-26-2009 03:53 PM
Help us have some fun... FrostyAK Off-Topic 28 01-20-2009 05:20 AM
Who wants some wheels? We have some wheels! Tuning Factory Inc. Wheels/Tires 286 10-02-2006 03:35 PM
