Old 01-27-2005, 05:48 PM   #1
Big Ern
Member#: 80128
05 Sti
WR Blue
Default Programming immobilizer keys
Hi all,
new Sti owner here. I am wondering if anyone knows how or has published how to program new immobilizer keys? I did a search with no luck.
Big Ern is offline   Reply With Quote
Old 01-27-2005, 06:12 PM   #2
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
As far as I am aware, you need the Select Monitor and ALL keys present to add a key to the system. In other words, the dealership does it .
Brian
Old 01-27-2005, 06:37 PM   #3
Jon [in CT]
Member#: 2992
02 WRX Sedan
The documents described at http://techinfo.subaru.com/html/ixSe...e=11&training= should explain the procedure.
Jon [in CT] is offline   Reply With Quote
Old 01-28-2005, 10:10 AM   #4
Big Ern
Member#: 80128
05 Sti
WR Blue
Just thought I would check. Mazda had the same story initially, then someone found in the service manual the 5 min procedure to do it yourself without paying the stealer, I mean, dealer $100.
Old 01-28-2005, 02:12 PM   #5
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
92 5MT SVX
Unfortunately, they state you need a Select Monitor and the Immobilizer Cartridge for it to program keys. Looks like no easy end-user method to program them.
Brian
Old 01-29-2005, 02:12 AM   #6
Pakin
Member#: 17315
MY95 Impreza 207C
MY05 Forester 257X
There is no way to do it manually. You can program the remote manually, but not the key. Maybe someone should make an aftermarket programming unit for the immobilizer
-paK +1
Pakin is offline   Reply With Quote
Old 01-30-2005, 11:10 PM   #7
Big Ern
Member#: 80128
05 Sti
WR Blue
I'm suprised that it is not doable. All you really need to do is "teach" the immobililzer the new key code. It must be a different system than my Miata. On the Miata you go through several steps to put the immobilizer in "learn" mode. Evidently TI makes a lot of the immobilzer chips (and made recent headlines due to someone "cracking" it) but the Miata had another brand beside TI. I had an extra key for a Miata so I tore it apart to see how it works. Oh well, I guess I will not make a backup key at this point.
Old 01-30-2005, 11:12 PM   #8
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
You should have 3 keys for your car....2 regular keys and a 'valet' key...
Old 02-13-2005, 12:50 PM   #9
antimullet
Member#: 44193
2008 WRX STi
Well, First, where is the immobilizer, and anyone know how to remove it to go get it programmed with keys.
Also, what if you have a reflashed ECU (05 MY) and its not the original. SO then the immobolizer doesn't see the ecu and it don't start. SO, If I take my ecu to the dealer with the immobilizer and keys, can he program it all? Also the link above doesn't work it wants money for the tb, can you copy it and paste it to a useable link?
antimullet is offline   Reply With Quote
Old 02-13-2005, 11:27 PM   #10
RexyGirl
Member#: 63616
1996 Volvo 850 Turbo
with mods :)
the car, original ECU and all keys must be present to have keys programmed. It has to be done with the Select Monitor and a special cartridge
RexyGirl is offline   Reply With Quote
DEI 556U + immobilizer key? Liam Car Audio, Video & Security 28 04-15-2011 10:41 PM
Need Info on Immobilizer Keys/ECUs Crawdads Subaru Conversions 5 07-12-2007 03:25 PM
Immobilizer keys moosebs09 Legacy Forum 2 07-30-2005 11:02 PM
Immobilizer key problem, '05 FXT lark6 Car Audio, Video & Security 7 12-15-2004 11:23 PM
Immobilizer key Question CXspeed Newbies & FAQs 2 04-16-2004 02:12 PM
