Old 01-27-2005, 07:18 PM   #1
Lever2ooo
Member#: 51708
**** your hippy
Default Dead o2 Sensor only after 9k miles
I installed a TBE maybe 9k miles ago, my car currently has 15k miles on it and my rear 02 sensor that screws into my PDE downpipe seems to be dead already, is this normal?
Lever2ooo is offline   Reply With Quote
Old 01-27-2005, 07:33 PM   #2
ScoobyNubieToo!
Member#: 75234
2004 WRX Wagon with
07 STI 6-Speed Goodness!
What makes you think it's dead? Are you getting a check engine light? Are you using any kind of ecu management or CEL defeats?
ScoobyNubieToo! is offline   Reply With Quote
Old 01-29-2005, 03:45 AM   #3
Lever2ooo
Member#: 51708
**** your hippy
I got a CEL for it but my downpipe has a bung for the 02 sensor
Old 01-29-2005, 11:22 AM   #4
mmorningstar
Member#: 73432
2008 Ford Mustang GT
Performance White
Subaru had to replace my second 02 sensor almost as soon as I picked up the car, it was defective, the car had 400 miles on it when it first threw the code, it was replaced under warranty and I've not had a problem since.
mmorningstar is offline   Reply With Quote
Old 01-29-2005, 11:45 AM   #5
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
perhaps you are throwing the CEL for a cat inefficiency?? and not for the reason of having a dead O2 sensor?
jigga is offline   Reply With Quote
Old 01-29-2005, 11:57 AM   #6
ScoobyNubieToo!
Member#: 75234
2004 WRX Wagon with
My thoughts exactly...
Old 01-29-2005, 11:58 AM   #7
WRXVT
Member#: 17979
335i Blue
is it P0420? - that's cat not 02
WRXVT is offline   Reply With Quote
Old 01-29-2005, 12:32 PM   #8
TKDKracker007
Member#: 52492
2014 WRX Premium
sexy dirty black
And the sensor is getting too hot with the lack of cats, and is throwing a code. If you keep the sensor, get a mechanical fix (screws into DP bung, and sensor screws into spacer). I went that route, no problems in 5k.
TKDKracker007 is offline   Reply With Quote
I nead a dead o2 sensor. Sir-Knight Normally Aspirated Powertrain 0 05-14-2010 06:18 PM
Exhaust manifold O2 sensor dead after PnP stockers?? STidub Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 9 02-21-2008 03:52 PM
Hesitation in 1st gear only -- after new front O2 sensor install? bpwatts UTEC 2 08-03-2007 02:15 AM
Brain-dead O2 sensor fix. HamFist General Community 0 08-28-2004 11:53 PM
02 sensor CEL after 1000+ miles? sjscooby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 08-19-2004 04:37 AM
