Old 01-27-2005, 07:44 PM   #1
SlowPoke00
Member#: 72361
2002 Impreza WRX
Hey ho Silver, away!!!
Exclamation Car overheating & radiator fans not turning on
After "burping" my cooling system, my car still overheats when idling (but stays at normal temps during regular driving with heater on). And I think it's overheating because when the fans are supposed to turn on when idling, they never do. So, after checking my fuses, none looked blown, but I changed them anyways, just to be sure... and they still wont turn on automatically. Any guesses on whats wrong with my car? I cant even drive to work without my car going over normal temps when idling at a stop light...
Thanks in advance
SlowPoke00 is offline   Reply With Quote
Old 01-27-2005, 08:54 PM   #2
cnk
Member#: 10757
2013 BRZ Limited 6MT
Did you check to make sure the fans are plugged in? Check to see if the fans work?
Calvin
cnk is offline   Reply With Quote
Old 01-27-2005, 09:20 PM   #3
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
Do the fans turn on when the A/C is switched on?
Old 01-28-2005, 01:32 AM   #4
SlowPoke00
Member#: 72361
2002 Impreza WRX
i dont have access to my car atm, but will tomorrow... the fans are supposed to turn on when the ac is on?
Old 02-03-2005, 02:22 AM   #5
Al_Smokemcrack
Member#: 66640
1997 Legacy Outback
Glacier White
Both come on when the AC is on and only the driver one comes on when the coolant is hot-ish and the AC is off. You should check your fan relays (in the relay box next to the Fuji nameplate on mine, probably still there) and the fuses. You could also unplug the fans and hook power up to them via wires directly to your battery to see if the fans actually will go when powered, though do be careful that you don't overheat the wires or catch them in the fan or anything. I'd hate to see you get hurt taking my advice.
Al_Smokemcrack is offline   Reply With Quote
Old 02-06-2005, 06:18 AM   #6
okaythisnamewilldo
Member#: 54512
2004 wrx prem
pearl black
Default not trying to change subject....
My right fan (looking in at my engine) has never been on even when ac is on, at least I dont t think so. And everytime I get my oil change I need to burp my engine.... This isn't natural is it? And also is this problem serious?????
okaythisnamewilldo is offline   Reply With Quote
Old 02-06-2005, 09:08 PM   #7
SlowPoke00
Member#: 72361
2002 Impreza WRX
ok, the fans do turn on when the AC is on.. what do you guys think is wrong, my coolant temp sensor is bad?
Old 02-07-2005, 09:52 AM   #8
vile
Member#: 32371
'02 t-rex wagon
platinum
^^^ very possible. i had a similar experienced on my gf's car (not a suby). have you tried running your ac at a stop light? if your temp does not rise, that's one way to tell your radiator fan is not running. also, is the car idling higher then normal, even after the car is warmed up? do you notice a decrease in your mpg?
btw, her car did not pop a cel for the longest time, but once it did, it was the cts
vile is offline   Reply With Quote
Old 02-07-2005, 02:43 PM   #9
SlowPoke00
Member#: 72361
2002 Impreza WRX
its idling higher than normal, even after its warmed up. It idles maybe at 1k or just under... not the normal 500rpms.
Old 02-07-2005, 08:44 PM   #10
ImprezaVA
Member#: 32846
1998 Impreza L-SOLD
Arcadia Green
Post
That'd be my guess.
-Charles-
ImprezaVA is offline   Reply With Quote
Old 02-08-2005, 02:19 AM   #11
Al_Smokemcrack
Member#: 66640
1997 Legacy Outback
Glacier White
I second that. While you're messing around in there, why not install a real water temperature gauge? It's another fun piece of instrumentation to look at.
Radiator fans not turning on aurelius Newbies & FAQs 6 02-25-2010 05:45 AM
Radiator fans not turning on dan avoN7 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 01-23-2006 12:29 PM
Radiator Fans wont turn on SlowPoke00 Electrical & Lighting 4 01-25-2005 08:45 AM
Radiator fan not coming on. So it seems. ebeck Electrical & Lighting 15 12-21-2004 11:40 AM
Radiator fans not coming on with link plus Midwayman Engine Management & Tuning 6 09-15-2002 01:28 AM
