Go Back   NASIOC > NASIOC Technical > Factory 2.5L Turbo Powertrain
Old 01-27-2005, 08:15 PM   #1
loudbay
Member#: 72474
Default why the torque curve of the legacy engines?
Is it just the turbo that has this characteristic? everything else i could find said the engines were the same....
two LGT stock dyno graphs
http://legacygt.com/forums/showthrea...ght=dyno+chart
a d.d. dyno read an ecutek relashed lgt at about 208hp and 215 tq here
http://legacygt.com/forums/attachmen...achmentid=3101
and 202hp 231ftlbs
http://legacygt.com/forums/attachmen...achmentid=1083
211hp 250ftlbs with stage 1 cobb ecu flash 14.7psi....
http://legacygt.com/forums/attachmen...achmentid=3748
and official cobb results
stage 1 285hp 305ftlbs totally stock lgt 14.5psi MOST of torque by 3k
stage 2 300hp 345ftlbs 3 inch dp and 2.5 inch mufflers (2 of them) 16.3 psi and max torque at 3200rpms! I like that!
http://www.legacygt.com/forums/showthread.php?t=6872
To be honest, I kind of like those last 2.... that would be a very useable engine for autox.... i wish i could shut my brain down sometimes... Matt
loudbay is offline   Reply With Quote
Old 01-27-2005, 10:00 PM   #2
XT6Wagon
Member#: 524
04 STi
You can get massive midrange on a Sti using the same methods of tuning.
Also the stage 1 map is intentionaly detuned on the AP. Don't know why, but it is.
XT6Wagon is offline   Reply With Quote
Old 01-27-2005, 10:06 PM   #3
roadtalontsi
Member#: 64572
2007 Sti
Swp c/f'd out.
Are the cams the same on sti and legacy gt?
roadtalontsi is offline   Reply With Quote
Old 01-27-2005, 11:44 PM   #4
Tuning Factory Inc.
Vendor
Member#: 3600
Here are more charts of some tests I did recently.
Stock v. Uppipe and Godspeed Downpipe. Stock everything else.
Here stock v. Uppipe, Godspeed Downpipe and Accessport
Tuning Factory Inc. is offline   Reply With Quote
Old 01-28-2005, 12:07 AM   #5
loudbay
Member#: 72474
290ftlbs at 3400 rpms would be a slayer in mygc8.... sux you have to use the intercooler and manifold to use this turbo easily.....
Old 01-28-2005, 12:23 AM   #6
santofontana
Member#: 26876
1994 Camaro Z28 383
Black M6
Sorry for the dumb question but what turbo do lgts have?
santofontana is offline   Reply With Quote
Old 01-28-2005, 12:31 AM   #7
Timdog1650
Member#: 45516
MY04 STi
vf40. Tiny little hotside...it's just a baby!
Timdog1650 is offline   Reply With Quote
Old 01-28-2005, 05:40 AM   #8
chucktoo
Member#: 59539
2005 Outback 2.5 XT
It is really helpful to look at the boost curve at the same time.
I think you will find the VF-40 just runs out - it is really tiny.
Today the biggest drop in turbo is Deadbolts 18G which is still pretty small. If you want a real turbo today you have to change a lot of plumbing .
chucktoo is offline   Reply With Quote
Old 01-28-2005, 06:56 AM   #9
happasaiyan
Member#: 37731
'07 TL-S 6MT
'07 RDX-T
the vf40 has teh suck.
happasaiyan is offline   Reply With Quote
Old 01-28-2005, 09:36 AM   #10
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
Those are very nice gains with very minimal mods. Have you tested a full turboback yet (do they even exist)?
mbiker97 is offline   Reply With Quote
Old 01-28-2005, 10:49 AM   #11
Tuning Factory Inc.
Vendor
Member#: 3600
Well you can team up my downpipe with a Blitz Nur Spec Touring cat back and you have a turboback.
My wishlist: Why can't we operate on the lean side of the EGT curve? PirateSanchez Engine Management & Tuning 5 02-08-2010 11:52 PM
HP/Torque Curve of 2.5L DOHC GTWagon_Phreak Legacy Forum 12 09-22-2005 12:56 PM
Oh, the voluptuos curves of this luscious body... Heavy Fuji Off-Topic 22 03-20-2005 08:46 AM
Why isn't the throttle plate on the intake side of the turbo? Dale_K Newbies & FAQs 3 03-15-2005 03:02 PM
When you launch hard does your car torque over to the right side of the road? kenshiro Factory 2.0L Turbo Powertrain 6 02-04-2003 02:57 PM
Message Board Statistics All times are GMT -4. The time now is 06:29 PM.
