Old 01-28-2005, 02:02 AM   #1
Derk1127
Member#: 9134
2000 Impreza RS-T
BRP w/Hydra+EJ257
Default Help please. Tuning RS-T at Idle
I have a 2000 2.5 RS-T which i added a Split Second FTC-1 fuel and timing controller into as well as 420cc wrx injectors. When i start my car it idles at 1100ish just fine but after a couple of minutes the idle drops and it goes into the 700ish range then it starts to stumble and die. I have no idea what is causing this as i have tried leaning out the map as well as richening it, i have gotten the Short Term Fuel trim and Long term fuel trim to within 5% at idle and it still keeps doing this am i playing with the wrong part of the map? Also i am throwing a P0301 and P0303 CELs which i think is related to my idle woes.
Also, when i try to start from a complete stop the engine hesitates and sometimes stalls, i think its related to the problem above. if you guys have any suggestions it would be great whether it be mechanical or tuning related. I have checked for vaccum leaks and there dont seem to be any. thanks
Derk1127 is offline   Reply With Quote
Old 01-28-2005, 02:07 AM   #2
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Are you altering the timing down that low? Chances are if you are correcting for injectors that much by changing the load the ECU is seeing, you are likely getting the wrong amount of timing at idle.
Also, I say good luck to you. I never got a perfect idle unless I let it idle at like 12:1 A/F ratio.
Old 01-28-2005, 02:11 AM   #3
Derk1127
Member#: 9134
2000 Impreza RS-T
BRP w/Hydra+EJ257
i havent touched the timing at idle, on the ftc can you advance timing, you can only retard timing which is what i thought. do you have any maps for the ftc? thanks
Old 01-28-2005, 05:53 PM   #4
Derk1127
Member#: 9134
2000 Impreza RS-T
BRP w/Hydra+EJ257
any suggestions guys?
Old 09-22-2005, 07:44 PM   #5
kgb
Member#: 1366
2000 RS-T -> RSTi-8
Blue Ridge Pearl
Hate to bring up an old thread - but I'm wondering if you manage to solve your idle problem. I read that in NA form, the stock ECU advance by 10-12 degree on 87 octane. So I theorize that with higher octane, to maintain the AFR at idle to be around 14.7 you would need quite a bit of advance - just how much becomes the question.
kgb is offline   Reply With Quote
Old 09-22-2005, 09:41 PM   #6
rgt
Member#: 50815
2007 Impreza WRX STi
WRB on Gold
At startup the car runs richer than normal. As the car warms up it leans out. If you tried to correct it by making run richer you did the wrong thing.
rgt is offline   Reply With Quote
Old 09-22-2005, 10:09 PM   #7
kgb
Member#: 1366
2000 RS-T -> RSTi-8
Blue Ridge Pearl
I'm talking about idling when the car is warm - right now, I can only get down to 13:1 before the car wanting to stutter and die. And through some experimenting, I found some setting that seems to get me the stoich idle but it's weird how I got it.
Help me Troubleshoot, Running Lean at Idle, Fresh Swap just fired up! morrocco88 Subaru Conversions 5 02-03-2010 02:17 AM
MY99 RS surges at idle? falnfenix Normally Aspirated Powertrain 2 03-12-2007 10:29 AM
Help car wants to overheat at idle seven881 Normally Aspirated Powertrain 5 03-16-2003 09:58 PM
Help please, 02 RS Cusco OS front strut bar installation... windfactory Bay Area Impreza Club Forum -- BAIC 4 07-02-2002 04:46 AM
Help please, 02 RS Cusco OS front strut bar installation windfactory Brakes, Steering & Suspension 0 06-27-2002 09:24 PM
