Vancouver Impreza Club
Old 01-28-2005, 04:35 AM   #1
bwco
Member#: 44137
Default Sway bar Q w/pic
I wanna see if anyone can educate me on this one.... I know i'll get a better answer from the open forums, but I thought this is such a stupid question, I'd rather play it safe here before embarassing myself in the open forum.
I wanna know the forces that act on the entire sway bar, endlink, and lateral link bracket
Red arrows denote -- forces from the sway bar pulling up and down(towards sky or ground) on the endlink.
Blue arrows denote -- forces of the sway bar pushing or pulling (towards the left and right wheel)
Yellow arrows denote -- forces of sway bar pushing or pulling (towards the front and rear of the car)
Which force(s) is/are correct under normal circumstances of cornering ?
-- I've an answer in my mind but I wanna confirm it (it's been bothering me for months....
-- I knew all the facts about stiffer/looser bar, under/over steer, heavy duty/stock/heim joint endlink effect, spring compression/stiff bushings...etc.
bwco is offline   Reply With Quote
Old 01-28-2005, 11:26 AM   #2
tedski
Member#: 67944
1990 325ix
trail buster II
Main objective is up & down, in other words - red arrows
Ted
tedski is offline   Reply With Quote
Old 01-28-2005, 12:53 PM   #3
AllWheelDrift
Member#: 9191
2002 Impreza 2.5TS
Blue Ridge Pearl
Yeah, the only way it should move is up and down, though it won't be perfectly up and down since it rotates around the mounts/bushings causing the end to move in an arc, so as it moves in the red directions, it will move in the yellow direction a small amount as well. However, all the forces should be acting in the red direction. Any movement in the blue directions is bad.
AllWheelDrift is offline   Reply With Quote
Old 01-28-2005, 05:37 PM   #4
bwco
Member#: 44137
So I don't have to worry about the sway bar forces pushing the stainless steel spherical bearing out of the endlinks (because of the blue arrow forces), right?
When I jack up the car on one side, I see a movement based on the yellow arrow, and the sway bar tend to pull the endlink and thus, results of the red+yellow direction.
Thanks in advance
Old 01-28-2005, 05:48 PM   #5
AllWheelDrift
Member#: 9191
2002 Impreza 2.5TS
Blue Ridge Pearl
OK, I lied. Because the latteral links which the endlinks are bolted to also move in an arc there will be a small amount of movement in the blue direction but I don't think you could get anywhere close to the forces that would be required to push the spherical bearing out of the endlinks. BTW, perrin endlinks also use spherical bearings but the bearings they use are much smaller.
Old 01-28-2005, 07:50 PM   #6
bwco
Member#: 44137
I've similar set up as th ones shown on the picture above
1) STI pink lateral link set
2) STI pink trailing arms
3) Custom spherical bearings endlink
4) STI 20mm rear sway bar
The spherical bearing endlinks has a listed ~5000+ lb of resistent against forces like the blue arrows. Since I'm no physican, all my predications were based upon SFU 2nd year physics standard.
The answer I got from open forums is that the endlink will only see forces like the red arrows. Nothing else !! But I kinda doubt it...
Old 01-28-2005, 08:09 PM   #7
AllWheelDrift
Member#: 9191
2002 Impreza 2.5TS
Blue Ridge Pearl
Well, the other forces are pretty insignificant so you can probably disregard them. There just needs to be some articulation to allow the link to move in those directions (which the spherical bearings provide) so that the endlinks don't bind.
In any case, the stock plastic endlinks seem to hold up reasonably well so I really think your mind can rest at ease.
Old 01-28-2005, 08:14 PM   #8
tora
Member#: 5851
09 Forester XT
+ NA Miata
Yes, to AWD's post, and keep in mind Billy, you drive like a girl. Maybe you need another lesson...
tora is offline   Reply With Quote
Old 01-28-2005, 08:33 PM   #9
bwco
Member#: 44137
shhhhhhhhhhhh...................
Didn't you see a granny burn out in a S2000?
Old 01-28-2005, 08:34 PM   #10
bwco
Member#: 44137
I've ditched the stock plastic endlinks long time ago, I'm using a custom heim joint endlinks now. Same thing as the picture provided above but with a different finishing.
Old 01-28-2005, 08:39 PM   #11
AllWheelDrift
Member#: 9191
2002 Impreza 2.5TS
Blue Ridge Pearl
I know, I'm just saying stock works and what you've got is better so stop being a worry wart.
Old 01-28-2005, 08:42 PM   #12
tora
Member#: 5851
09 Forester XT
+ NA Miata
Worry wart, that's the coolest two words!
Old 01-29-2005, 04:20 AM   #13
bwco
Member#: 44137
yeah, stock works well only if I have the stock lateral links, but I've the pink stuff that have a different position for the endlink mount. Stock sway bar should work fine, but I've a jdm sedan rear sway bar. Stock endlink should work fine, but I bought my endlink pieces by pieces and build it from scrap. I went to home depot, lots of measurements and guesstimate. Bang, went under the car and done all by myself. Well, under so much uncertainty, I'm worried about the safety of my brilliant life
Old 02-05-2005, 08:54 PM   #14
sniece
Member#: 9935
Hey there BWCO, I'm building up a set of heim joint front (and hopefully rear) end links as well. What size (if anything) did you have to use to space the end link out from the swaybar?
Thanks,
Steve
sniece is offline   Reply With Quote
Old 02-05-2005, 09:19 PM   #15
bwco
Member#: 44137
sniece, I build it exactly like the ones from poltec.... look into the dealers' forum and u'll see. I'd a few detailed pictures of it before...
Basically, get some bolts with flat ends or some thick round washers (I'm not sure what they call them, but it's basically a spacer. Make very accurate measurements as which heim joints you should buy, then go from there and get all the necessary bolts and nuts for it. The pair of endlinks spend me less than 50 bucks canadian.
Old 02-06-2005, 08:59 AM   #16
sniece
Member#: 9935
Yeah, I have the joints themselves already, and I found 3/8 long x 1/2 OD aluminum spacers at McMaster Carr, but they had to be bored out to 3/8 to work. I THINK they'll be the right length, like you say, I can probably judge the size off of the Poltec pictures.
Thanks!
Stephen
Old 02-07-2005, 05:00 AM   #17
bwco
Member#: 44137
good luck man.... !
FS : 06 OEM WRX Rear Sway bar with OEM Endlinks pointblink19 Suspension/Brakes/Handling 3 06-07-2010 11:51 PM
Which sway bar bushings? z0rz Brakes, Steering & Suspension 10 06-05-2010 07:03 AM
A sway bar is a sway bar is a sway bar?? eightballrj Brakes, Steering & Suspension 7 07-06-2004 07:58 AM
anyone have a pic of the blue white line sway bar? wop Brakes, Steering & Suspension 4 07-17-2001 09:08 PM
