Old 01-28-2005, 02:50 PM   #1
TimStevens
Member#: 4817
2012 STI, '02 WRX
'91 MR2, '05 Speed Triple
Default UNIX dudes - help with nohup
I have some processes I'm going to be kicking off that'll take a couple of hours to run, and I'd rather not be logged in to run them. So I tried this:
nohup ./somescript.sh -someflag -param1 /path/to/file.xml -param2 /path/to/bla.log &
It starts, directing output to "nohup.out", but immediately stops, and the only thing in nohup.out is "somescript.sh: bad substitution".
Thinking something was wrong with using args like that, I tried writing another script that basically just contains the above call, and tried this:
nohup ./dumbscript.sh &
But, same problem, bad substitution in nohup.out, only this time it says "dumbscript.sh" has the problem.
Any idears? Usually Google Groups has solutions to all things relating to error messages, but I'm not having any luck.
TimStevens is offline   Reply With Quote
Old 01-28-2005, 02:53 PM   #2
Hypernoodle
Member#: 12391
I did her 5 times
then 7 times, then 5 more
I know this might sound dumb, but try passing the full path for the script and see if that does it.
Hypernoodle is offline   Reply With Quote
Old 01-28-2005, 02:56 PM   #3
TimStevens
Member#: 4817
2012 STI, '02 WRX
i was actually using ./, which I forgot to type above, but I'll try that.
In the dumbscript.sh I did use the full path to the other script.
Old 01-28-2005, 03:14 PM   #4
TimStevens
Member#: 4817
2012 STI, '02 WRX
Hrm, no dice. Same error.
I just discovered you can use nohup -p to control a process that's already running, so maybe I'll just kick the app off, get the PID, and do it that way.
Would love to know what the problem is, though, if anyone has any ideas.
Old 01-28-2005, 03:23 PM   #5
Hypernoodle
Member#: 12391
I did her 5 times
Okay...
Instead of calling the script directly, preface the full script path with the "sh" command.
nohup sh ./somescript.sh -someflag -param1 /path/to/file.xml -param2 /path/to/bla.log &
Old 01-28-2005, 03:32 PM   #6
kbcr3
Member#: 44170
2010 Forester XT
05 and 09 honda ruckus
can you just run it in cron later in the day or night?
kbcr3 is offline   Reply With Quote
Old 01-28-2005, 03:40 PM   #7
bigdweeb
Member#: 31035
13 Ford Explorer
14 ISM STi
why not just run screen, start the process and detatch the screen session. Then reattach later to check progress.
bigdweeb is offline   Reply With Quote
Old 01-28-2005, 03:46 PM   #8
TimStevens
Member#: 4817
2012 STI, '02 WRX
You mean Ctrl-Z and bg and fg? These don't work if you log off.
I can't really cron this stuff, since I don't know how long each process will take, and I need to run each in sequence, but need to verify the previous run was successful before kicking the next one off (it's essentially a batch load of data to the DB, the script calls a process to load it). So, I need to start them manually.
I'll try the sh option. My understanding was you only needed that if your files weren't set as executable.
Old 01-28-2005, 03:49 PM   #9
bigdweeb
Member#: 31035
13 Ford Explorer
14 ISM STi
no, not what I meant... screen is a process that you can run. I allows you to run a shell and then disconnect from it, but you can leave stuff running still. When you want to check up on things you reconnect to the machine and then reattach to the screen session as if you never left.
Old 01-28-2005, 05:31 PM   #10
Kartoffel
Member#: 12976
grocery getter
Yes. screen will get the task done nicely.
Kartoffel is offline   Reply With Quote
Old 01-28-2005, 07:10 PM   #11
TimStevens
Member#: 4817
2012 STI, '02 WRX
I've never used screen before, but from the manpage it sounds like it needs a windows manager..? Unfortunately I'm running these commands on a machine I only have telnet access to.
Old 01-28-2005, 07:46 PM   #12
Kartoffel
Member#: 12976
grocery getter
The "window" is simply your tty. Just play with it locally to get a feel for it.
Once you're logged in, start a screen with
Code:
screen
Start your job(s)
Code:
stuff blah etc
Then detatch screen with ctrl-a, ctrl-d. You are free to log out.
When you log back in later, reattach to screen with
Code:
screen -r
and you'll pick back up right where you left off. Awesome, huh? Screen is good stuff.
You can also use screen to mux two ttys together, so that two users can see the same thing. First user starts screen with `screen' as usual, the second user does `screen -x' to attach to the existing screen. Now, whatever one user types will appear on the other's tty. This is handy for interactively helping n00bs or for collaborative editting, etc.
Old 01-28-2005, 07:56 PM   #13
sct
Member#: 20644
Good overview post. The one point I have is that on my boxes it is just "CTRL-A d".
I am using it all weekend to do some server migration. Certiainly one of the most useful tools to a sysadmin or batch processor there is.
sct is offline   Reply With Quote
Old 01-28-2005, 08:14 PM   #14
linux>windows
Member#: 49517
Still need help?
linux>windows is offline   Reply With Quote
Old 01-28-2005, 09:26 PM   #15
TimStevens
Member#: 4817
2012 STI, '02 WRX
Nice, thanks guys. Appreciate the help. I'll give that a shot when I'm back to work on monday
Old 01-28-2005, 09:56 PM   #16
linux>windows
Member#: 49517
oh, good luck..
Old 01-29-2005, 12:36 AM   #17
Kartoffel
Member#: 12976
grocery getter
yay for weekends
Old 01-29-2005, 03:59 AM   #18
sct
Member#: 20644
Weekends are nice. I only have to work part time. Thank the lord I am salary. Oh wait, that isn't so special.
Old 01-29-2005, 08:28 AM   #19
TimStevens
Member#: 4817
2012 STI, '02 WRX
yay for weekends
Yeah, seriously, it's been a bit of a long week. I'd log in and try it out now, but I'll probably be doing some work over next weekend, so I'll take this weekend to chill out
Old 02-17-2005, 02:41 PM   #20
TimStevens
Member#: 4817
2012 STI, '02 WRX
Thought I'd give this a bump since I finally had time to get back to this.
screen looks like it'd work perfectly, but unfortunately it's a GNU package and the admin won't install anything on there unless there's a system need. I'm sure he'd dig it if he tried it, but alas, it's not going on there.
But, I got nohup to work. Turns out I made a stupid mistake on the script I was calling, forgot the #!/bin/bash at the beginning of the script. Put that in and nohup works fine. Much more clunky than screen sounds, but not much I can do aboot that.
Thanks for the assistance guys.
Old 02-17-2005, 03:08 PM   #21
aod
Member#: 7121
I missed this thread somehow. You should be able to run a process in the background and detach your tty without it killing the process as well. Nohup is not really necessary anymore with shells that have job control. Nohup was necessary back in the days of shells without job control. You can background a process by putting an & at the end of the command line. You should be able to logout at that point and the process will not receive a HUP (Hang UP) signal, hence no need for nohup. Of course, being a programmer I'm sure you are familiar with signal trapping. If you wanted to go a step further just to make sure, you could make your process ignore HUP signals.
aod is offline   Reply With Quote
Old 02-17-2005, 03:11 PM   #22
TimStevens
Member#: 4817
2012 STI, '02 WRX
Well, it's a Java app, so I'd imagine that's up to what the JVM does with it, and I don't know honestly. It's worth trying, though... after the first batch job completes... which should be sometime tomorrow morning
Old 02-17-2005, 03:13 PM   #23
aod
Member#: 7121
Is it just running through jre? If so, you should be able to background it no problem.
Old 02-17-2005, 03:14 PM   #24
TimStevens
Member#: 4817
2012 STI, '02 WRX
Yep, the 1.4.2 JVM running on Solaris 8.
Old 02-17-2005, 03:16 PM   #25
moktod
Member#: 34768
2002 Impreza WRX
install 'screen'
use it
love it
never look back
-moktod
p.s.
let me know when you have it installed and I will give you my quick howto.
moktod is offline   Reply With Quote
Need help with something truenosan Vancouver Impreza Club Forum -- VIC 7 06-02-2010 09:05 PM
Help with greasing up the bushings kmper02 Newbies & FAQs 1 06-02-2010 03:52 PM
Java/J2EE dudes - help me with a DataSource problem re92 Off-Topic 1 03-01-2005 06:36 PM
Need help with some UNIX commands. Kinsbane Off-Topic 9 04-05-2004 11:51 PM
please help with unix PhantomOG Texas Impreza Club Forum -- TXIC 17 10-20-2001 10:11 AM
