Old 01-28-2005, 05:57 PM   #1
CBoldman
Member#: 11411
Default Accessport with Delta Dash
Hey guys. A buddy of mine might be purchasing a delta dash system for his WRX. I would like to use it (DD can operate with 3 ECU versions if I am correct) but Im curious as to the effects of running the AP. Ive heard that the AP changes the ECU version, but does it do this each time I change a map? Hope I make sense with this question, thanks guys. -Chris
CBoldman is offline   Reply With Quote
Old 01-28-2005, 06:40 PM   #2
Famink
Member#: 44890
15 WRX
GBP
I would like to know also? if I under stand it right you might be using a licences every time you flash the Base Map (would hope not on a Real Time Map)?
Famink is offline   Reply With Quote
Old 01-28-2005, 08:53 PM   #3
hondaeater69
Member#: 60324
Do a search, I've seen this question asked and answered before. . . .I'd answer it but I can't remember what the answer was
I believe "crazymike" (sn) has DD with the AP. Try pming him if you have no luck with your search.
You may also want to wait until the street tuner comes out, it'll have datalogging capabilities. IF you can wait
Old 01-28-2005, 11:47 PM   #4
crazymikie
Member#: 56321
2006 Honda El Camino
Green
Did someone say my name?
Once you use an AccessPort, your ECU type will be changed. It doesn't change each time you reflash, though. It will stay changed even after unmarrying at this point. If you look at post #179 here,
http://forums.nasioc.com/forums/show...5&page=8&pp=25
Trey explains it all. He also talks about something that will allow a user to change the ECU type on an AccessPort by AccessPort basis.
Also, just for future search purposes:
http://forums.nasioc.com/forums/showthread.php?t=672784
Hope this helps.
Mike
crazymikie is offline   Reply With Quote
Help with Delta Dash display StiDreams Engine Management & Tuning 4 11-09-2004 12:51 AM
Tuning with Delta Dash on an Ecutek Reflash Tuned Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 10-04-2004 09:43 PM
anyone with delta dash? onesillyracer2k2 Tri-State Area Forum 2 09-07-2003 01:51 PM
Knock signal at idle with Delta Dash maugustine Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 09-05-2002 03:18 PM
A/F with Delta Dash mynew02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 25 06-05-2002 01:10 AM
