Old 01-29-2005, 12:06 AM   #1
Miggidy
Member#: 71343
2000 Impreza WRX GC8
Default 6mt in Aus spec My99 WRX (GC8)?
Ok guys I have searched but could find nothing.
I have a My99 WRX (GC8) and want to upgrade to 6 speed is it possible to use the MY01 sti tranny?
What are my options?
THanks in advance
Miggidy is offline   Reply With Quote
Old 01-29-2005, 01:12 AM   #2
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
you can swap in 6spd with clutch modification (push in vs push out) plus the driveshaft
Hyper is offline   Reply With Quote
Old 01-29-2005, 01:37 AM   #3
cronic
Member#: 9749
Are you doing the 01 rear end too?
cronic is offline   Reply With Quote
Old 01-29-2005, 02:31 AM   #4
Kotir
Member#: 17300
1993 Widebody Wagon
625whp e85
I think you need a 6 speed clutch it should be the same type of clutch but while you're at it you might aswell do a new clutch
(He already has a GC8 WRX which should have the turbo style transmission)
But as said before you may have to swap your rear diff, axles, huibs etc to match it to convert to a R180 with the correct final gear.
Kotir is offline   Reply With Quote
Old 01-29-2005, 12:57 PM   #5
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
you can do it. you can use a Re worked R160 so you can keep the rear hubs you have now
scobaru is offline   Reply With Quote
Old 01-29-2005, 01:20 PM   #6
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
as soon as I get a car, I will start doing something
it doesn't matter, he still has the old GC 5spd which is a different design then 6spd
Old 01-29-2005, 01:50 PM   #7
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
as long as he has the hydraulic style clutch it doesn't matter push/pull is more for the impreza L's that have the cable clutch which involves lot more work.
a few guys on around here has done the 6speed in the GC body
Old 01-30-2005, 11:37 PM   #8
Miggidy
Member#: 71343
any ideas in the price for a drivline swap such as that?
Old 01-31-2005, 12:31 AM   #9
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
I've looked in to it its around 4000-5000+ if your really lucky you can find it for around 3500 I VEry rarely see it go for that much
ECU pinouts / Wiring Diagrams for the UK (EURO) or JDM or AUS Spec 2004 WRX mistaboosta Engine Management & Tuning 5 09-29-2010 11:57 PM
lightened flywheel on a 6MT in a 2.0L WRX ProdriveDreams Subaru Conversions 1 12-18-2009 05:55 PM
Lightened flywheel on a 6MT in a 2.0L WRX ProdriveDreams Transmission (AT/MT) & Driveline 0 12-18-2009 02:52 AM
helix DP on Aus spec wrx? bdsrld22 Newbies & FAQs 3 04-26-2007 02:10 PM
ne1 interested in uk-spec 17" wrx wheels? Benjamin Tang Vancouver Impreza Club Forum -- VIC 28 06-08-2002 07:17 PM
