Old 01-29-2005, 02:08 AM   #1
Pakin
Member#: 17315
MY95 Impreza 207C
MY05 Forester 257X
Default Complete list of bolt sizes in Subarus
I'm trying to find a list that has all the sizes of bolts used on a Subaru. And yes, I will be getting to every bolt one day or another
So far I know:
10mm
12mm
13mm
14mm
17mm
19mm
21mm
22mm
27mm?
32mm
There might be a 30mm, on a axle nut?
Edit: Note that these are referred to head size.
Anyone have anymore ideas, or corrections?
Thanks,
-paK +12
Pakin is offline   Reply With Quote
Old 01-29-2005, 11:09 AM   #2
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
05+ WRX transmission bolt is a T70. While I applaud your moxie, this could be a BIG project. I started a Torque FAQ once with the torque specs........I got a day into it and had a huge, huge list that eventually crushed my will power to type.
Old 01-29-2005, 06:36 PM   #3
Hank3
Member#: 16157
'03 Mazda P5 <><
'02 WRX & '08 MS3 SOLD!!!
- Una bows down to Subaru bolts.
Don't blame you though; I would've lasted till the idea of doing it. Wouldn't have even made it to typing the list out...
Hank3 is offline   Reply With Quote
Old 01-29-2005, 09:03 PM   #4
Alan
Member#: 3601
2006 WRX Wagon
BRIGHT BLUE!
I'm fairly positive there's some bolts that need an 8mm wrench. And I assume you are talking about wrench (head) sizes, because bolts are usually measured by their shaft diameter so it's 6mm bolts that have 10mm heads.
Alan is offline   Reply With Quote
Old 01-29-2005, 10:11 PM   #5
Pakin
Member#: 17315
MY95 Impreza 207C
MY05 Forester 257X
Correct. As you mean such as a 14mm head corresponds to a 8mm diameter? I should note that.
Much thanks,
-paK +0
Old 01-31-2005, 11:56 AM   #6
Ging
Member#: 3258
2000 Impreza TS
I think the axle nut is 32mm.
Ging is offline   Reply With Quote
Old 01-31-2005, 02:00 PM   #7
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
Much thanks,
-paK +0
IIRC the exhaust bolts that have 14mm heads are M10s. The head size is sometimes unrelated to the actual size of the bolt though (hehe I said head size).
This project you are trying to start is exceedingly difficult. Good luck.
mbiker97 is offline   Reply With Quote
Old 01-31-2005, 02:59 PM   #8
Storm
Member#: 5218
96L Most Over-
Developed Beater
Ooohhh.....big task. It would probably be best to also include thread pitches as well as lengths since some are odd sized that must be ordered if you want to get replacements.
My workplace has ironically ordered quite a few Subaru-compatable nuts/bolts as of late....
Jay Storm
Old 01-31-2005, 07:56 PM   #9
BAN SUVS
Member#: 28685
2004 FXT 4EAT
very STi'd
Brake bleeders are usually 8mm (wrench size).
BAN SUVS is offline   Reply With Quote
Old 02-01-2005, 02:35 PM   #10
vrg3
Member#: 25796
1993 Legacy Turbo
Burgundy
I'm guessing you just want to have a known-sufficient set of sockets or something that can do anything on the car? Sounds like a worthy cause.
What on the car is 13mm and 27mm?
I believe the rear differential's drain and fill plugs take 13mm square keys.
The clutch fork rod in the transmission takes a 10mm allen key.
vrg3 is offline   Reply With Quote
Old 02-01-2005, 03:32 PM   #11
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
It's setup for a 1/2" rachet.
Old 02-01-2005, 03:44 PM   #12
vrg3
Member#: 25796
1993 Legacy Turbo
Burgundy
Are you positive it's 1/2" and not 13mm? The difference is a scant 0.3 mm.
Old 02-01-2005, 10:35 PM   #13
Pakin
Member#: 17315
MY95 Impreza 207C
MY05 Forester 257X
Some bracket bolts under the headliner. It's hard to believe when I first encountered it, but the 13mm fit best. But I don't think anything engine related has 13mm headsize bolts.
27mm had a (?) mark to it since I wasn't sure, but had some thought of it.
-paK +4
Old 02-02-2005, 11:43 AM   #14
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
If you want to buy another tool go ahead, but a 1/2" wrench fits perfectly.
http://www.scoobymods.com/forums/showthread.php?t=3
Old 02-02-2005, 12:42 PM   #15
R_W
Member#: 76896
There is definitely several 8mm, transmission ground wire @ firewall, and some trim screws.
Robert
R_W is offline   Reply With Quote
Old 02-02-2005, 01:38 PM   #16
adeliciouspizza
Member#: 7844
05 STI CGM 450whp
05 FXT CGO Stock
i wouldnt say it fits "perfectly". yes its a good enough fit to get the job done. i always use my 1/2" drive breaker bar. however... its still a very loose fit and if the bolt was in there really tight you might have problems and/or cause some damage.
adeliciouspizza is offline   Reply With Quote
Old 02-02-2005, 11:14 PM   #17
Pakin
Member#: 17315
MY95 Impreza 207C
MY05 Forester 257X
Robert
Are you saying an 8mm bolt size or head?
I've done many trannmissions (both MT and AT) removal related stuff and I've only seen 10mm head on the ground wire to firewall.
-paK +3
Old 02-03-2005, 05:06 AM   #18
vrg3
Member#: 25796
1993 Legacy Turbo
Burgundy
A lot of the hose clamps under the hood have 8mm heads on them.
And I do recall some of the mud flap screws on a 1st-generation Legacy having 8mm heads.
Old 02-03-2005, 02:53 PM   #19
R_W
Member#: 76896
-paK +3
Hmmm.....You may be right, I was thinking head (wrench) size. Maybe it was a 10. I do remember that the upper left light trim screw was an 8mm (cause I used it to pull the throwout bearing pivot, and forgot to tighten it when I stuck it back in!)
R
Old 02-04-2005, 04:29 PM   #20
fragment
Member#: 8050
2004 FXTi - Stage 2
Goooooooolld
The bleeder screws on the Brembo's are 11mm. I couldn't believe it. Took me 15 minutes to find the damn thing.
fragment is offline   Reply With Quote
Old 02-08-2005, 01:02 PM   #21
R_W
Member#: 76896
R
Okay, Okay, had the hood up yesterday, they are both 10mm.
I promise not to post inebriated, I promise not to post inebriated, I....
R
Old 02-08-2005, 01:22 PM   #22
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
The screws holding the IC shroud to the hood are 8mm heads IIRC.
Lookig for a Complete List of SCCA Autocross Rules for Street Mod Spun Autosports Motorsports 7 04-10-2006 01:42 PM
Where can I get complete listing of WRX part numbers? igalwrx Service & Maintenance 5 05-08-2004 10:56 PM
Anyone have COMPLETE listing of parts for hydro clutch conversion? Aspen Subaru Conversions 14 01-31-2004 03:54 AM
Need complete list of people who would like a new carpet for there car CUNNINGHAM Interior & Exterior Modification 22 06-12-2001 11:28 AM
Complete List Of Turbo Kit Suppliers For RS subarumantoo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 03-28-2001 09:43 AM
